Where does the tach hook to |
Geno
Senior Member Joined: September-05-2007 Location: United States Status: Offline Points: 179 |
Posted: October-23-2007 at 6:23pm |
on a 70 separator? Pete put up a wiring diagram but I can hardly read it and it seems to be gone now. Thanks.
geno, Like this one?? It would be a gray wire.
TRDon
Groupie Joined: December-22-2006 Location: United States Status: Offline Points: 65 |
always typical to see the tach signal derived from the ground on the coil.
85 2001 351 240hp FS
93 sport |
Geno
Thanks so much!
1969cc
Groupie Joined: February-22-2005 Location: United States Status: Offline Points: 84 |
Geno
Are you hooking up a new tach or your original 1970 tach? My 1969 Mustang with my original tach hooks to the positive terminal of the coil. Fred |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21125 |
Thats interesting. I thought all coils had +12V (or a little less if using the ballast resistor) on the + terminal. The - terminal connects to the distributor (ign module/points) and will read between 0V and 12V, depending on the position of the dist, creating a pulsed signal to drive the tach. How would a tach get a signal from the + terminal? |
Geno
Hooking my original tach up to see if it works. The coil is a Mallory that my stepdad put in and he may not have hooked the tach back up.
1969cc
TR
My original tach has a yellow send wire. When I hook up my o'scope on the + terminal of the coil the pulse is present. I recently tried to hookup a newer style tach with a gray send wire to the + on the coil and it did not work. I had to hook it up to the - terminal of the coil to get it to work. Fred |
Interesting! I wonder how the old tach pulls the signal off the + side. |
1969cc
TR
http://www.tachman.com/fordhkp.htm Check out the above link for Faria tachs. My hookup is similar to this. The tach is hooked up in series. Fred |
