thermostat |
BOBM
Newbie Joined: May-27-2005 Location: United States Status: Offline Points: 18 |
Posted: April-18-2007 at 7:18am |
Hi,
Anybody out there know where I can get a thermostat for a 65 Chrysler 318 polysphere motor? I've looked for months, can't find one. Thanks, Bob |
Barracuda
Moderator Group Joined: November-17-2003 Location: United States Status: Offline Points: 998 |
The Lake
heath
Newbie Joined: September-25-2006 Location: United States Status: Offline Points: 39 |
Bob,
I am having the same problem you are. Marine parts.com say they don't make the screw in style anymore, that housing or the relief valve(allows passage of water to exhaust manifolds). So i purchased the newer style housing and thermostat. I did not like the way the thermostat went in and I dont think it is working correctly. If I find out anythi8ng else, I will let you know. Also I am having trouble with my water pump (dual pocket sherwood). Maybe we could exchange phone numbers and discuss our issues. I have been wanting to talk with someone who has the same engine I do. |
'cuda
Barracuda
Does your t-stat look anything like this?:
Barracuda
Bobm and Heath- Here's the closest replacement stat I could find. And it didn't solve the problem (overheating). It wasn't the dual impeller Sherwood pump either.
If you'd like to talk over the phone, email me your #s. -Brad |
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
Bob I had a 65 Barracuda and found the front bypass and manifolds from Blue Ridge Marine in Lynwood Washington. I can't remember the guys name but he had a bunch of parts and was very knowledgable. I ran mine without a thermostat and everywhere but Lake Tahoe it ran at 155. At Tahoe 6000' 60 degree water it ran at 145
Thephantomkaw
Senior Member Joined: April-05-2007 Location: Chattanooga, TN Status: Offline Points: 201 |
You can run them without a thermostat?
~Michael~
87BFN owner
Not a good idea to run with out one as the motor will never warm up to operating temp. Which will cause the boat to run rich.
79nautique
or remove moister from the block and cause a lot of problem down the road, it's all right to do if it sticks close and you need to get back in but don't run it without one. |
