  New Posts New Posts RSS Feed - Dwell
Dwell
YooperSully View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YooperSully Quote  Post ReplyReply Direct Link To This Post Topic: Dwell
    Posted: June-16-2010 at 4:03pm
I have a petronix electronic ignition upgrade in my distributor, does this void the need to check dwell?
87' 2001
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2010 at 4:13pm
yes, no points no dwell to set, but you still have to set the base timing and verify the mechanical advance is working correctly. Also Read the installation instruction and verify the need to remove or use the ballast resistor per the instructions.
