Price for PCM351 and Trans |
pmccook1
Senior Member Joined: November-12-2007 Location: United States Status: Offline Points: 143 |
Posted: March-24-2008 at 10:43pm |
What kinda price should I be looking to pay for a PCM 351 and trans out of a 1976 Ski Nautique. Runs good and the trans has no problems.
Thanks |
pmccook1
Current boat:1993 Ski Nautique " Purple " Have owned : 76' ski nautique, 93' Sport Nautique, 83 Stars and stripes, 47' Chris Craft Continental |
eric lavine
it varies, $400.00 to $800.00 i would say anything over that he would be taking your money, there are good deals out there if you search, thats me though
if you are searching for a trans try to find a 10-17 series, stay away from the as1-71c, the 10-17's will have all the updates |
Luchog
Eric, what updates would that be?
eric lavine
2 reverse plates instead of 1, seal ring planetary instead of bushings, different baffles, updated hydraulic system.
the biggest difference is the reverse, they went deeper in the case and added another friction and a steel seperater plate, even with the 2 plates they still have a tendency to snap in half |
pmccook1
400 to 800 bucks for the Engine and Trans together ? or that price for each ?
Thanks for the info |
pmccook1
eric lavine
both
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Online Points: 7950 |
How much is the guy asking?
Eric, Did the Dearbo make it on the truck yesterday? |
eric lavine
no, it left today, 3 days with fed ex, call me when you recieve
Riley
Awesome. I will, thanks!
Riley
Eric, tranny arrived today. Looks great. Thanks!
Bruce, Did Eric paint over the ID tag on the trans?? |
eric lavine
your welcome Riley,
no tag Pete, but if it had one it wouldve got paint lol Eric, I really do only paint over the nasty looking tags cause they stick out like a sore thumb if you dont |
Riley
Pete, LOL nope. I asked him not to paint it because I am going to paint the engine, so I might as well as do the tranny at the same time. The tranny is all aluminum and is clean and shiny like its new. I may not paint it. What do you think of that?
BuffaloBFN
Eric, I'm sure you made the right decision on mine?!!? LOL The tag matters less when it's smooooth!!! Thank you for the good work...and I hope it likes Pumpkin Pie?!!? LOL |
Hollywood
behindpropeller
That sure is a gamble.....
I doubt the parts are worth $1000 |
Riley
And, I bet it's a LH.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21124 |
Almost without a doubt. Supra was using the same powertrain as CC in the early 90's, with a LH 351w mated to the 1.23 to swing a RH prop. Plus, the fact that the guy says it can be used in a truck means its gotta be a lefty. I agree that its not worth $1k in parts. The block/heads/intake are only worth a few hundred, and what else is there? Circ pump, oil pan, carb, valve covers? His starting price is a stretch. Its pretty clear that he swapped over all of the good parts onto his new engine. |
Riley
Malibu was using the same powertrain as CC in the 80's, (as an option), with a 1:1 and a LH prop.
Wouldn't that block would be worth considerably more if it were RH? |
behindpropeller
Block does nothing with rotation, it is the CAM.
You would need a reverse water pump too. Tim |
Tough to say. While the RH engines are a lot more scarce, there are also a lot fewer people looking for them. Tim, youre right (mostly), but I think the whole point of buying this engine would be to drop it in and go. To convert it to a RH would involve a cam swap, rear main seal swap, checking the piston offset, etc. At that point youre better off buying a bare block as opposed to one thats already assembled. |
