intake and ignition |
peter1234
Grand Poobah Joined: February-03-2008 Location: United States Status: Offline Points: 2756 |
Posted: February-27-2008 at 10:32pm |
hi guys next question .. does anyone know if the 4 barrel and offy intake is original on the universal v6 skylark? also is there an electronic ignition available for the same? Peter
I have to say no on this one. I always thought they came with a 2bbl. I just took a look in the diaries and found the V6's show the 2bbl's. Without internal engine work, a larger carb usually doesn't do much. How does yours run?
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Online Points: 7949 |
Peter, I looked at your boat and thought that setup was aftermarket.
Peter you'll have to look on your distributor for a make and model and then check here-
http://www.shopatron.com/index/591.0.26484.26485.0.0.0 It might be best to call them and ask.Then check with someone like Summit,they seem to have good prices. |
peter1234
Hi all I got the boat from skyfuzz it seems to run great. I figured it was an aftermarket set up. I wouldnt mind an electronic ignition in it or maybe just a super coil to spark it a bit hotter.
Peter, Without other engine mods, I don't feel you will gain anything except starting IF you have a starting problem. I'm not real big on the pointless conversions. I've run one of my boats for 28 years without a tune up and do know that if stuck due to a point issue that I can borrow my wifes nail file to get home. With the pointless you are stuck! Maybe this summer I'll give it a tune up!
Tim D
I would say that electronic ignition makes my boat more responsive on acceleration.
Tim D
