big block |
84bare12
Groupie Joined: February-24-2008 Location: United States Status: Offline Points: 47 |
Posted: February-24-2008 at 1:25pm |
I need help!!! I'm having a hard time moving my big block right and left for alignment, let me know the best way. I have everything lose and it won't budge
Mark 84bare12"
Mark, You may need to use some penetrating oil on the mounts. They can be stubborn at times. Then a pry bar and some wood blocking between the engine and the mounts and it should move. In extreme cases, the mounts may need to be removed and loosened up on the work bench. This is true with any engine and not limited to a big block.
I,m glad you found us at CCfan. You'll find lots of knowledge and plenty of helpful people here. Fill us in on the boat and better yet, post some pictures. |
boat dr
Mark, welcome aboard......
As Pete noted these things have not been moved in a while,so.... A small chisel or large screwdriver driven between the seration while liberal amounts of penertrating fluid are applied will sometimes render them movable. But if all else fails , do not hesitate to Rove and repair.Not a time consuming jobto remove and a lot easier than replacing broken parts after the fact......Boat dr |
eric lavine
if you do end up removing the mounts which you probably will end up doing, i will put them in a blast cabinet which some guy's may not have access too,
another great way to clean them is a bench mounted wire wheel, once cleaned i will paint appropiate parts and never sieze the rest, once done you should be able to adjust the side to side easily with small pry bar. It sounds like the alignment has'nt been attempted in some time. good to hear your doing the alignment, where did you hear about alignment? |
Behl
Senior Member Joined: December-05-2006 Location: United States Status: Offline Points: 404 |
If you do not want to remove the mounts and first try a penetrating oil I would try "BP Blaster" penetration oil. It seems to work best for us.
If you do remove do be sure to put on Anti-Seize as Eric said. |
84bare12
thanks for your input guy, I noticed on the front mounts a big difference in space from right to left, But the couplers are real close. I read the front mounts should be 1 3/4 on each side is this so!!
Mark 84bare12"
84bare12
Also when i split the couplers,I noticed the shaft side coupler has alot of play, I Know that's not right. So I'm assuming the coupler is worn do to motor alignment.
Mark 84bare12"
Mark, Don't worry about the engine not being centered exactly in the middle of the boat. The hulls aren't the most precise things around. The important thing is to understand that the alignment starts with the strut and then goes forward. If the shaft is is centered in the strut cutlass bearing and roughly centered in the hole in the bottom/shaft log, then align the engine to the shaft.
The coupling to the shaft is a press fit so with all that play you mentioned, it has been run for some time without a alignment. The worst problem mis alignment can cause is blowing the output bearing (and then the seal) on the trans. How is it? As long as you are going with a new shaft and coupling half, now is the time to put a new dampener plate in on the trans. How many hours are on the boat? |
84bare12
The trans seams to be fine,800 hours, looking at the motor it appears to be centered visually, but the front mounts space is very different, motors never been aligned so I'm assuming it's always be that way or the motor moved tho i find that hard to believe
Mark 84bare12"
eric lavine
a good indication of mis-alignment over the years would be a loose prop shaft coupling, it tends to take the abuse of mis-alignment and tries to act as a u-joint and works on the shaft causing wear, if you pull it off easily and has rust in that area then your coupling is worn.
84bare12
thanks for your input, you have been a big help!!! I will pull the shaft to determine if the shaft needs replacing. hoping it's just the coupling. The u-joint theory really makes alotta sense. thanks again.
Mark 84bare12"
What Eric is describing with the rust is quite common in mis aligned mechanical power transmission. I've had mechanics come to me with a rusty shaft, sheave, sprocket, coupling, etc. They will tell me that there is no water in the area and are confused about the rust. "Fretting" as it is called will actually be more without any water! Here's a link to a good explanation if anyone is interested. fretting Mark, Make sure you mike the diameter of the shaft if you are thinking about using it again. The wear from fretting is worse on softer materials (the stainless shaft). |
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
Thanks Pete
Now you've got me fretting about fretting. Steve |
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
SNobsessed
If that info on fretting doesn't make you a believer in maintaining alignment, I don't know what will. 82% decrease in fatique life!
eric lavine
Steve, wait till we get you burnelling
