Replacing a rub rail |
aokcaldwell
Groupie Joined: October-11-2007 Location: United States Status: Offline Points: 95 |
Posted: June-22-2008 at 1:15pm |
Update for all who helped. The railing went in great. Pre drilled all new holes. Two people and a hot sunny day made the install go easy. Suggestions were very helpful, omitted the "whacking" step though.
Also, kept the wife and am considering adding on to the garage! Thanks, AC. |
aok142
1999 NSS GT40 Pro Boss |
behindpropeller
Time to get a new wife or another garage. |
Don't try to match the old holes. They will never be perfect and you do not want buckles in the rail. This is also the reason they have recommended just snugging up the screws and not really tighten then.
aokcaldwell
Come on guys, throw me a bone. Woody shipped me the rubrail kit and it's still in the same location. In a box on the floor! Besides, my wife said she loves the boat but if I don't get it out of the garage before winter, she said I can name the boat "Divorce"
aok142
east tx skier
Senior Member Joined: August-22-2006 Location: Tyler, TX Status: Offline Points: 248 |
Thanks for the info and the offer! You don't need to go to the trouble of sending your extras to me though as much as I appreciate it. I only need one and probably have one in the toolbox. Thanks again. |
aokcaldwell
OK. Got conflicting reports. (2) reputable CC dealers said they don't use the old holes. They put the new rail up, drill a small pilot hole and put a screw in about every 3'. Also, he said make sure to have a heat gun to get around the bow and the curves at the stern than go back and drill in the remainder of the screws in. All CC dealers stated not to tighten too much as you will see where every screw was driven in. They also stated that if you hit an existing hole just leave the screw in it and drill another one next to it. Does this sound about right?
AC. |
aok142
aokcaldwell
Yes, they are 1 1/4" stainless steel screws with a #2 phillips head. Give me your address and i'll ship you a dozen. They are my old ones and I received new ones in my rub rail kit.
AC. |
aok142
east tx skier
The screw is bent to the point of not being able to put it in. |
James, that list doesn't need much the way it is!
87BFN owner
HW is going to have fun with the guy saying not to worry they can take quite a whacking.
behindpropeller
Yeah. Just put the screws in and use a hammer to get it straight!!!
east tx skier
Anyone know off hand what size screws are in there. I have a bent screw I'd like to replace.
aokcaldwell
Here is the link you told me about. Thanks!
AC. The rub rail can be replaced, it's actually not all that hard. The biggest problem is getting the screws through the new rub rail and into the same holes on the deck. Procedure: 1.) Remove end caps 2.) Remove insert 3.) Remove screws from rubrail 4.) If not already there, score a line above the screw holes but, below the rubrail height. This will prevent any spider cracks from the screw holes to come up past the rubrail. 5.) Warm up new rubrail. Either put into a box and put a hair dryer running on it or leave it in the sun. It'll be much easier to work with. 6.) crayon or grease pen a vertical line above each screw hole above the rubrail for reference when inserting new screws. You want to drive the screws into the same holes so, this will let you know where the screw holes are. Don't drive the screws in tight because the new rubrail will be wavy otherwise. Just get them sorta tight. Don't worry about it being too perfectly straight at this time, just get it close. 7.) You'll probably need somebody to help you, for holding it in place as well as pulling it tight. Will also need a heat gun to warm up the rubrail to get around the nose. 8.) Once the rubrail is installed, check for straightness. If not straight, whack with rubber hammer until straight. Don't worry they can take quit a bit of whacking. 9.) Install insert. Again use rubber hammer to get it into the slot. 10.) Install end caps. 11.) If you have any marks or anything on it you can get a rag with some Acetone on it and clean up the rubrail. 12.) Crack open a beer and admire your work. |
aok142
aokcaldwell
Thanks, I'll look.
AC. |
aok142
bkhallpass
There was a fellow on planetnautique.com who has done this several times. He posted a pretty good step by step process. If I recall, he was an advocate of using the same holes and had a method for doing so. You might do a search there. I think his name on planetnautique is wakejunky. BKH
Livin' the Dream
TRDon
Groupie Joined: December-22-2006 Location: United States Status: Offline Points: 65 |
I would see if it lines up with existing holes. If not caulk or epoxy them and pilot drill new ones for sure or stress cracking might become an issue
85 2001 351 240hp FS
93 sport |
aokcaldwell
I removed the rubrail from my 95 Ski Nautique and am replacing it with a new kit. Do I try to drill into the old holes that are random or caulk the old holes and drill new holes. If so, do I need to drill a pilot hole prior to srewing in? Any hintS, ideas or suggestions?
AC. |
aok142
