  New Posts New Posts RSS Feed - Fuel Pump Question
Fuel Pump Question
miker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote miker Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Pump Question
    Posted: August-11-2004 at 7:15pm
Restoring my 69 Barracuda...I've had it since 1970. The original fuel pump finally gave out and gas started spitting from the vent. On the older models the vent did not have a tube running to the carb or flame arrestor.
I notice most all the replacement units are now a kit....new pump, new flame arrestor with a vent tube hole and tubing for the vent to the flame arrestor.
I'd like to keep this original and found a carb kit...diaphram, gaskets, etc. for the original pump.
I'm sure the newer version is safer, but just curious if anyone has insight into this, or has been through the same issue?
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2004 at 4:47am
My '72 has a small glass bowl that traps the vent and is contained. My 2 cents, the idea of the line running to the carb could be dangerous.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2004 at 4:39pm
IMHO: Although it is comendable that you want to keep your boat original, there is a lot to be said for safety...especially when dealing with fuel spills in an inboard boat. I would suggest you go ahead and upgrade to a pump that is vented to the spark arrestor. The vent tube is clear so you can see when the diaghram (sp?) has ruptured. You will also know it due to a rough and rich idle. Better safe than sorry or original. Just my $.02.
