Velvet drive ignorance |
Justin131313
Newbie Joined: March-09-2007 Location: United States Status: Offline Points: 27 |
Posted: March-20-2007 at 6:33pm |
O.K. here goes an attempt at the stupid question of the week award. I am just very curious about how the velvet drive works in my 85 nautique. It works so much better than other old boats Ive driven. No clunking into gear, smooth and solid. Does anyone know where I could see an expanded view of all of the parts. Or does anyone have a pic of the inside of one, or a disassembled one. Obviously there is a gearbox that engages an extra gear or something for reverse, but the smoothness? It feels like it has a torque converter similar to an automatic transmission. Does it? I am new.
Justin131313
nevermind, found it in the reference section.
eric lavine
Now you know why they call it a velvet drive...
it does not have a converter the prop more or less in a way is the converter, a converter is a hydraulic connection on cars. a converter acts like a clutch as it does on a stick shift car, the reason you dont need a converter on a boat is that that the prop turns unhindered when put into gear and will not stall the engine. reverse goes through a set of planetaries,(a set of gears inside of a sun gear) which allows it to reverse, the whine you hear in reverse are the planetary gears spinning aproximately 5 times engine speed and the helical cut on the gears cause the whine |
backfoot100
Eric, thanks for that explanation. I've been wondering why most tranny's have that whine in reverse ever since I first heard it.
I have to agree with Justin131313 about my tranny. It's so smooth, never a hint of a slip, no clunks, grinding, or whining(in forward anyway). It seems to just keep going effortlessly and all I do is change the fluid and when I do that, the fluid looks like it was just changed yesterday. Yet I hear horror stories from others about the problems that they seem to have constantly with their tranny's. I know from other posts that the alignment has a lot to do with that. Is that the only reason for these issues from others or is there something else that can cause problems? Of course, assuming that they change the fluid regularly. Some others I've seen seem to run fine but they're noisy as hell. They have a terrible whine in forward and even worse in reverse. Do I just have a good one with exceptional alignment (I've never checked my alignment) or am I just good at dodging bullets? |
100, I think allot has to do with who's transmission it is. I seem to get the idea from Eric that if it isn't a B/W then there are more problems. I think you should take the time and check your alignment.
David F
I once had a BMW with a V-12 engine. The starter motor gave out and I opened it up to see what was wrong. I was surprised to find a planetary gear set, but then understood why it was there. The gear set multiplied the torque of the very small starter motor(small to fit in a very tight space) which made it possible to spin the 5.0L V-12 engine. It also explained the very unusual noise that the starter motor makes on all BMW V-12's...sounds like a chain saw cutting through a tree (whine). |
eric lavine
Paragons use spur cut gears (straight teeth) which makes the planetary very noisey, if you notice on older cars(manual transmission) when you put them in reverse and back up you'll hear them whine, this is due to spur cut gears and also they will grind when shifted because of no synchros on the gear
hspore
Senior Member Joined: January-11-2006 Location: United States Status: Offline Points: 164 |
Eric, with your service hat taken off, in reality, after how many hours should you change the tranny fluid in the velvet drive?
I was told 50-75 unless you do a lot of forward/reverse aggressive driving/skiing. |
Heath
JoeinNY
The smoothness of the velvet drive once I got my first inboard was a massive surprise to me and all my fellow skiers who were raised on outboards and i/os. We have replaced our old "In Gear" shout to the skier/boarder with the somewhat longer but much more fun "Velvet Drive Engaged". I am sure there are people all along the shores of owasco lake that wonder what the heck that means....
-Joe. |
eric lavine
Heath, once a season is a good routine, there are guys out there that never change it and those are the guys i like. during winter along with winterizing I recommend filling the trans to the very top, doing this keeps the seals oiled and prevents a rust line inside the case, of coarse drain it completely in the spring and add fresh. there is no reason the transmission shoulnt last 25 years if maintained properly and this includes alignment
fixitjim
Newbie Joined: May-04-2006 Location: United States Status: Offline Points: 27 |
I have been inspired to change my transmission fluid this weekend. I have a 93 Ski Nautique and have never changed the fluid. I have only about 400 hours and it runs perfectly but as you say Eric, you love people like me. I never knew it was so important until reading all this information here! I guess I have been very lucky. Thanks for all the great, helpful information on this site.
fixitjim
eric lavine
im putting myself right out of business....lol eric
Dont worry, for every one guy on this site there is about 1000 other guys with these trannies, those are the ones I prey on |
