color codes. |
cableguru
Newbie Joined: February-21-2007 Status: Offline Points: 3 |
Posted: February-21-2007 at 11:47pm |
who can I contact for cc color codes....restoring 83 2001 to original
thx roger cableguru8@aol.com |
Roger
hasbeenskier
Roger, what colors are you refering to, gel coat or graphic paint? The reference section may tell you what colors they are by name but not by code. I am restoring an 81 S.N. and although I know the hull is Ivory Taffy, I cut a 1.5" hole out of the gunnel underneath a step plate where the sun had never affected the original gel. Then I had it matched perfectly.
hasbeenskier
cableguru, Minicraft of florida or U.S. Composites will be able to match gel coat colors with your hull # molded into the transom.
Dtaylor373
Senior Member Joined: June-30-2004 Location: United States Status: Offline Points: 167 |
I have the correct color codes and Mfg, put out by Correct Craft for that year. They were in the orginal paper work of a boat, I bought a few years ago I would be happy to fax you this info, if you like.
David T
