Trailer brakes |
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1809 |
Posted: January-28-2007 at 2:32pm |
Ok folks, we'll be wet pretty soon here in NY and we now own a vehicle that I can tow with. As you know, I have this 1980 American Skier including the original trailer. NY requires brakes on this trailer. What are my options, if any, of retrofitting the OEM trailer with brakes?
JayG80
Senior Member Joined: January-07-2007 Location: United States Status: Offline Points: 170 |
I have no idea...but you might call Quality Trailer Products (QTP) in New Holland PA 800-497-0986.
I had Ram-Lyn send me product literature on their trailer. They included a brochure from Quality Axle Division of QTP. Website is www.qtrailer.com They also sent a few pages on the brake actuator. I have a Titan Aero-6000 Actuator for trailer brakes. 800-872-2327 |
SkiBum
I have wanted to install brakes on my 87 SN trailer for some time. Cost has been holding me back. Can purchase backing plates with drum brakes from most boating outlets. The axles on my trailer already have the bracket needed to connect the plates. Need to buy some drums to fit. The actuator is easily installed at the tongue, replacing the standard hitch. Then, plum brake lines to the wheels. Looking at $500 or more.
But it can be done and isn't too hard. |
gn6027
Senior Member Joined: October-15-2006 Location: Ohio Status: Offline Points: 192 |
I added hydraulic surge brakes to my '87 CC trailer, and just as SkiBum indicates, it was all of $500 (more like $600) to do it right.
Go to DexterAxle.com. They have a great resource section. I ended up putting Dexter brakes on mine, and I've been very happy with them. I'll be happy to answer any question you may have. |
GN6027
1987 Ski Nautique 2001 |
duffnit
Senior Member Joined: October-12-2005 Location: United States Status: Offline Points: 235 |
I'd suggest a local fabrication shop that rebuilds trailers and such for parts. When my local guy doesn't have what I need I order from Champion Trailer Supply. (http://www.championtrailers.com/)
They have complete hydraulic drum kits that start around $250 and go up. Good source, and helpful info. Good luck. d |
Danny
"no offense- but the rate at which you spread bad information is very impressive" |
David F
The key to all of the above is whether or not your current trailer axle has the mounting plate for the brake a$$emblies. If not, you are looking at replacing the axle as well.
If you go the drum brake route, I strongly suggest you install the "free backing" type. |
gn6027
Guys, saw this Atwood coupler on ebay: Item #300080597192
Not sure of capacity, but it might go pretty cheap. |
GN6027
