oily mess |
Posted: July-22-2021 at 9:22am |
Naturally one week before our summer mini vacation I find this One more bolt to go- surprisingly the V drive came out easier than the trans so far
Gary,
Is it the Walters with the leak? If so, make sure you get their "super special no one else has them" seals.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10650 |
Seems to me that if the V Drive was leaking, he wouldn't be worried about getting the transmission out
And the Walters doesn't leak red stuff either
I wish - the vdrive was way easier to remove than the trans. The tell tail sign is the red fluid in the bilge,only the trans uses it. The Walter's use non detergent oil.
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3592 |
Any clue where your leak starts? Maybe the cooler? Good Luck
GottaSki
oh rat farts
I hope it works out
River Rat to Mole |
Thanks for the support- just got to power through it,seems like everything is breaking this year. Got it up on the bench and parts ordered- Skidim has everything in stock and is sending right out. It's a paper gasket between the front cover and the case. The pump mounts to that front "cover" - so as I understand from Zach who's walking me through this,the pump can stay in place but as I remove that front cover the drum comes out as well. So I'll get that all apart so that when the parts get here it can just go back together. Still got time- crossing my fingers. Number 18 in this picture-
Hats off to Skidim they sent out the parts yesterday UPS second day air-they arrived around 1030 this morning. Replaced the gasket,pulled the pump to replace the shaft seal and 3 o rings since it was that far apart. Did all of that in the garage while waiting for the boat to get shade, hot and humid all day. Could have got farther but when I needed that 3rd hand everyone was busy which was for the best as I could cool off. Zach warned me ahead of time but so far the hardest part was re installing that front cover,when you remove it the input shaft and the drum comes with it. When it goes back in the input shaft drops into a bearing and the drum has to align with the teeth of the clutch plates. Took several tries but finally popped right in. Now have to finish up the mounts,hoses,minor electrical and align. Should be ready to test tomorrow. Engine crane saved my back- sure has earned its keep.First I lift the trans off the bench, wheel it over to the boat then in on a 2x6 across the floor. I'm having a new pier put in,the guys doing it gave me a 5 foot section of 4" pipe that was left over. Slipped it over the engine hoist boom which than extended it enough to easily reach the center of the boat to do the heavy lifting. Since the angle is not as great as when getting it into the boat I don't have to worry about the sling slipping. Good thing I work cheap I think this would have been a expensive,long down time repair.
Hollywood
You have nothing but time
I have to be on the road by Wednesday to make it to Bubba's for lunch on Thursday......
Hollywood
Good thing is you can drive your car straight to bubbas
MrMcD
Nice work Gary, I really like the team red colors!
Mark PS. I have a similar hoist, I added a swivel hook to the hoist, it allows me to swivel the load smoothly 360* and made a big difference in usefulness. I think the 2,000 lb swivel ran $50 but worth every penny.
Gary, Was the seal bad or did the shaft have any corrosion? Ether way, great you got it.
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5311 |
Wow..... I'm impressed.... And to think you used to repair telephone land lines. You've come a long way young man. Looks like going to the gym has paid off too. Retirement is good to you Mr.Starr.
Pete that is what makes me nervous. There was some corrosion on the shaft which I cleaned with crocus cloth provided by IBT many years ago ;) but there was no oil in the bellhousing or anywhere on front end of the trans. Hoses and fittings were perfectly dry, cooler dry. Bottom inch of trans soaked, you could see oil in the seam. Gasket hard and brittle when removed but intact.
Tim in my young days I didn’t know what I wanted to do thought a automotive mechanic might be in the future. My dad said do you want to be standing under a car with the melting snow dripping on you when your in your 50’s?? Mom pushed me to the phone company since she had worked there many years before. Today marks 39 years that the young lady I met there have been married- she is spending the day watching her mom, I’m spending it in the boat. Mark thanks- you great taste in colors ;) I don’t think I paid more than 150 for that HF hoist it really has come in handy, 150 does not go far at the chiropractor! |
Gary,
We'll be crossing our fingers hoping for the best. I just looked at the picture again and it sure doesn't look like you're down south! Did you come north to cool down?
This job would be impossible down there,I had just the very minimal tool selection there or even the room to do this. Besides with that salt water this poor boat would have been a mess- fresh Fox River water only for this boat
SNobsessed
Gary - Do you think the gasket failure was just old age or was there another factor? |
My old age or the gasket Chris . I wonder if it relaxed and had it been able to be re torqued if it would have been ok? Don't know- like I said I wish the problem jumped right out at me. Anyway just walked in about a hour ago completely done. Cleaned up the bilge earlier and test ran it on the hose going for a water test in the am. Got it aligned don't know how or even understand the whole system- why is the engine and trans rubber mounted but the v drive which is mounted to the back of the trans has it's own mounts that are rigidly attached to the "stringers" I would think that would transmit noise and vibrations into the structure of the hull. Anyway got it to turn with one finger which is better than it ever was, sure is alot of stuff turning compared to a DD!
MrMcD
Gary, a young man would have struggled to get all that done in a couple days. You kicked some serious A**. Nice work. Hope the water test is equally impressive. Your mount comments has me thinking you may have found why the gasket failed. Paper gaskets seal pretty well but allow for zero movement. Vibration may have took it out. Have a cold beer or 6 and celebrate your win.
Success !
gun-driver
Great glad you got it fixed.
I don’t think I’d ever want an ass-pusher just because how difficult they are to get at when things go bad. PS; Why does it take you 24 hrs to get to bubbas, your not in the Deep South anymore?
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3887 |
WOW,
I am impressed that you tackled that project yourself. You should be proud of yourself. Those ensure drinks must be keeping you fit. LOL !!!! Donald
Cousin Don, Quinner and I have a master plan to come down and have the Chicago Chapter of CCF take over your operation. As you know he's already there setting up, it won't be long now we've both been bulking up- we'll see who laughs last.....
Donald80SN
Gary, Yes, about two weeks ago, I spent a full day with Quinner drinking adult beverages and floating in the lake. I took my female Chocolate Lab with me and Chris had is Male Yellow Lab with him. Before arrival, I warned my female dog that both Qunnier and his male dog are very likely to try to hump you so please be on high alert. It was hard to keep an eye on both of them at the same time, I am happy to report, no puppies were made. Donald
