  New Posts New Posts RSS Feed - Need a Thermostat
Need a Thermostat
BarracudaBay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BarracudaBay Quote  Post ReplyReply Direct Link To This Post Topic: Need a Thermostat
    Posted: July-12-2019 at 5:30pm
The thermostat on my Chrysler engine (350 HP) in my ‘67 Correct Craft Barracuda locked up while being commissioned this spring. Looks like I need a new thermostat. Any suggestions on where I might find a thermostat. My mechanic said they’re tough to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2019 at 5:51pm
So I’m replacing my screw in stat this weekend with a great conversion kit. Part number 2846215k (go2marine). And the oem stat for kit is 2600699 and same design newer version is cm-29-3675303.   My boat is the 67 Ski Nautique with a Chrysler 318. So probably same issue. Be careful not to snap bolthead off 50 yr old housing. Good luck it is well worth that old equipment gone and start with fresh bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2019 at 5:55pm
Rafe,
Fill us in on this engine. What have you done to it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: July-13-2019 at 12:11am
Yep. 383, or 440 ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote BarracudaBay Quote  Post ReplyReply Direct Link To This Post Posted: July-13-2019 at 1:54am
Sorry for the naive question... how can I tell if it’s a 383 or 440?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: July-13-2019 at 12:14pm
My 318 is 225hp. So a 350hp should be bigger. Engine casting numbers under heads on right side (right looking at motor front)). But I looked at marine express schematic I do not see a 383/440 option. Only 273,318,340. Could be the stat kit 2846215k fits all 60-74 Chrysler marine   Figure out what motor you have and call tech dept at marine parts sources MPS to verify stat compatibility   I replaced my screw-in stat and housing last night fits great with minor hose reroute. Also look for part number on your number intake manifold might help narrow down
Did you google thermostat 2846215k
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2019 at 10:56am
Can you post a picture of thermostat   Is it the side mounted large screw in type
Post Options Post Options   Thanks (0) Thanks(0)   Quote BarracudaBay Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2019 at 3:13pm
Thank you so much everyone. Here are some pics of the Thermostat and the pumps as well as the numbers on the casting... Any thoughts on the proper thermostat and pumps to be order would be amazing! Thank you all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2019 at 7:05pm
Rafe,
Where did you come up with the 350 HP? Most Cuda's had the 318's
For a T stat, you are better off converting with the kit that Daryn mentioned. Here's another source.
conversion kit
This kit: Thermostat housing kit
Used on all Chrysler V8 engines from 1968 to 1974
Replaces screw-in themostat used from 1960 to 1968
Includes thermostat, housing, hose and tee assembly
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2019 at 11:22pm
Good timing. I had that exact stat fail last week. Pics are exactly like mine. Really like new normal stat for replacement availability. BE CAREFUL removing old bolt. If you strip 9/16. The next down is14mm. If bolts snaps, we’ll chat again good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote BarracudaBay Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2019 at 1:30am
Thank you all for the feedback. I am ordering the stat kit!
I am also told I need to replace the Jabsco water pumps. Any suggestions for ordering the proper pumps?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2019 at 7:47am
Rafe,
Most likely what you have heard is to replace the rubber impellers and not the complete pump. Here's a recent post with a link to the impellers.
Jeromy,
You should need two impellers for a dual cavity RWP.
Here's a guide for impeller selection
How about some pictures of the Cuda? I and I know others would love to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2019 at 11:41am
Mine has a Sherwood D65 pump. But always check impellers first. There made to be replaced and.expensive brass body reused. However we do share same engine block casting. First year LA318 cool. Pictures please
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2019 at 11:47am
Pete and other grand poobahs here have saved my rear couple times. So happy to pass along knowledge that worked for me. I’m just learning about these Chrysler marine motors too. You will figure it out, if your diligent you can find parts you need. Enjoy
Post Options Post Options   Thanks (0) Thanks(0)   Quote BarracudaBay Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2019 at 4:36pm
Oops... sorry for the delay... here she is....
https://www.instagram.com/correctcraftbarracuda/
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2019 at 4:51pm
Nice!! And, it's a SS too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2019 at 5:11pm
Interesting color don't see many. What happened to the original shifter and throttle controls?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BarracudaBay Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2019 at 5:15pm
I'm not sure re: the shifter and throttle control... I purchased her used and the owner didn't have much information. I am eager to replace the stat and pumps so I can get her back in the water!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2019 at 8:52pm
Very cool. Center console awesome great color. What does as mean pete
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2019 at 9:43pm
The SS? Mustangs and Barracudas were available in a SS trim which were buckets and the center console.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2019 at 10:44pm
As was the Tahoe though not technically called an SS yet
