  New Posts New Posts RSS Feed - Motor swap help
Motor swap help
00065cccuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Topic: Motor swap help
    Posted: November-02-2018 at 6:39pm
I will keep posting progress on my project, my boat also will have a Ford engine as well maybe someday I'll come across a 65 318 poly motor, or I'll throw in a hemi love these old boat with onboard V8s there's not much to them and you can do whatever you want like an old hotrod.
93/70 ccpb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 93/70 ccpb Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2018 at 6:22pm
sorry in ohio dan monahan 1001 fairacres ave streetsboro ohio 44241     will send you a check for postage...my cuda came with a 351 ford put in by previos owner,i have a 318 poly as a extra will let you know if i decide to sell.but keep looking in your area,and ill keep an eye out over here
what you dont want to hear from jbear and bill.you cant get in the boat till you get your minute,and they throw you back in water!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2018 at 1:01pm
Yes I will transfer both to paper for templates you can use,if you live in the areas you could come by and I'll give you the wood templates.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 93/70 ccpb Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2018 at 4:26am
can you send me a copy of templates.im also working on a 65 barracuda ,my stringers were taken out before i bought it,thanks dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 11:43pm
Once the floor is in its off to body work and paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2018 at 11:40pm
Both stringer templates done spent the day hunting down Doug fir. Downs and reader great place for specialty wood. (2) 12' 2x10 was the same money as what i paid for my boat. Beautiful wood it's a shame once the floor is down you'll never see it again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 10:59pm
Had a problem posting pics this morning I'll try again tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2018 at 10:58pm
Bought 2 2x10 x12' boards this morning got one stringer template done hopefully tomorrow I'll have the other template complete. Then off to buy the real expensive Douglas fur and get them cut and epoxy them in and start the fiberglass work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 4:50pm
Stringer # 2 out! Time for a long shower lots of cutting fiberglass with the grinder all I can taste is 1965 fiberglass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 2:54pm
One stringer out one to go!What a royal pain in the A@#! Hopefully the second one is easier. I'll try to post some pics tonight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2018 at 8:19pm
Originally posted by 00065cccuda 00065cccuda wrote:
Going to use my left hand 289 because I just found out the trans can be set up for left or right hand rotation, I just took off the trans and it's clocked for left hand rotation already so looks like iam good to go. I know it's not correct but it's going to be a lot of fun.
You may have this rotation thing totally understood and then again you may not
You say that the transmission that you just took off I assume your 260 which is reverse rotation is already clocked for Left hand rotation so you're good to go.. This makes me think you may not understand.since Borg Warner looks at rotation differently (from the front looking back) so for your automotive rotating 289 you will need to set up the transmission for RH rotation The easiest way is to look at the arrow at the top and make sure it points the way the engine rotates.
In the interest of saving you a lot of aggravation and some time pulling and reindexing a transmission after it's already installed in the boat and doesn't work, you should read the thread in the link, paying particular attention to the direction of the little arrow. It's a lot of confusing reading and you might need to read it more than once.
You could post a picture of the front of your transmission showing the arrow and the LH stamping also
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2018 at 6:58pm
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2018 at 6:11pm
I suspect the 260 out of the barracuda.
So original option for this boat would be swap cam and crankshaft into the 289 and use all the 260 accessories.
Knowing now that the 350 is not a modern turnkey setupi wouldn't recommend it at all..
Early 318s of either flavor are certainly a nice option as well ...
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2018 at 6:04pm
Motor is out
Of what?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2018 at 5:11pm
Motor is out
DasBoot67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DasBoot67 Quote  Post ReplyReply Direct Link To This Post Posted: October-27-2018 at 6:29am
I have a 69 barracuda with a318 needs a rebuild job if interested let me know
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-26-2018 at 3:22pm
I agree I Am still on the hunt for that 65 318 it's not going to easy but I Am not giving up yet.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: October-26-2018 at 12:46pm
Given the purpose of the name of the boat originally was a boat with a Chrysler theme,
I'd say hold to find a 318 of either flavor (A or LA) . More fun yet a 340
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 10:17pm
The starter is mounted aft my guess its not FWF.
JDD33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JDD33 Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 10:07pm
I see your in MA.
I have a complete rebuilt RR 351 that might be an option for you.
Pm me if you'd like to talk.
John.
Old school goin back to school!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 8:41pm
It's a paragon trans didn't get the id # to see if its a reduction or one to one.
How old? Considering it has the Paragon, sounds like it's a Chris marinized SBC and is it a FWF (flywheel forward)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 8:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 6:56pm
The 350 is in a full inboard Chris craft Catalina 251 .
With a reduction trans?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 1:15pm
Believe me I would love to keep this boat original as possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 12:59pm
The 350 is in a full inboard Chris craft Catalina 251 the problem is I have to take the whole boat but it's complete and running not a bad option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 12:38pm
. I would love to have the drive line iam going to use while replacing the stringers.
I wouldn't worry about that too much, they both would use the same transmission and the motor mounts are adjustable for either in terms of height and the stringers are going to be at the same standard for either.   Worst case is you have to drill a couple new holes for your motor mount and fill in the old ones if you wanted to go with one over the other.   Poly engines still exist for sure as I have one in pieces around somewhere but all the parts get more difficult to find each year, so if you are looking for a daily driver a rh 350 is probably a good choice. as long as it was originally in an inboard boat and has all the expensive manifolds, pumps, brackets etc.   Although if someone has a running pullout poly they are cool getting rare enough to be cool,
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 11:53am
Thanks for the link, I would love to keep this project going original I believe the 318 is the only motor offered I just fell across that gm 350 and trans complete and it's the right rotation. I wish there were more options. There are a few more places to look for a 318 poly. I would love to have the drive line iam going to use while replacing the stringers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 8:38am
What I get out of this thread and your other one is that you don't know what you want to do with this boat.
A couple of times you've been asked if you want to do a complete restoration and keep it all original and a couple of times you haven't answered that question
Mr. Original (Pete) has given you a link to a couple of engines that didn't exist in 1965.
Those 318's in the link are LM series and you think you might want an original Poly head engine.
So..........if you decide what you want to do, that would be a big help
If originality doesn't matter and that SBC came from an inboard, has a Borg Warner transmission and has exhaust manifolds and is a running engine it might be a good choice for practical reasons.
Here's a link to a 350 Chevy in a Barracuda resto mod
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 7:37am
Rebuild the RH one.
Don't forget we'd love to see more pictures especially of the stringers you need to replace. Also, to keep everyone on the same page, maybe you should keep posting in your original thread?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 00065cccuda Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2018 at 12:54am
Thanks for the input I think that year came with the 318 poly motor. I still have time to hunt for an original power plant I need to replace the stringers first.
