  New Posts New Posts RSS Feed - tune up kits
tune up kits
wayner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayner Quote  Post ReplyReply Direct Link To This Post Topic: tune up kits
    Posted: June-18-2018 at 6:25pm
I cant seem to identify the exact OEM part number for a tune up kit for my 1988 correct craft, PCM 454 ci 330 hp. Engine number is pkr-wr-r10.   The distributor cap is a clip type with a screw to hold the clip in place.
Appreciate any direction
1988 Dominique 454
Wisconsin
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 7:07pm
If what you have looks like the first picture in the link (which is what I think you describe), then you can use kit part number 1301
from Ski Dim
It says it's for Ford 302/351's but the same parts fit a Prestolite for a Chevy.
If I was you I'd call Ski Dim just to verify this
If it's a different cap, look at the pictures to identify it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayner Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 7:16pm
Thanks, it looks like the mallory stack cap. It has clips that tighten with a screw (but not an actual screw down). I will go to the site to see what the kits look like. Thanks
1988 Dominique 454
Wisconsin
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 7:23pm
Looks like part number 1304 from Ski Dim
Your engine tag probably says PRK instead of PKR, just figured I'd mention that
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayner Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 7:30pm
You are correct, PRK. Transposed the letters. Thanks
1988 Dominique 454
Wisconsin
