tune up kits
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=42990
Printed Date: May-05-2024 at 11:36am
Topic: tune up kits
Posted By: wayner
Subject: tune up kits
Date Posted: June-18-2018 at 6:25pm
I cant seem to identify the exact OEM part number for a tune up kit for my 1988 correct craft, PCM 454 ci 330 hp. Engine number is pkr-wr-r10. The distributor cap is a clip type with a screw to hold the clip in place.
Appreciate any direction
------------- 1988 Dominique 454 Wisconsin
Posted By: KENO
Date Posted: June-18-2018 at 7:07pm
If what you have looks like the first picture in the link (which is what I think you describe), then you can use kit part number 1301 from Ski Dim
It says it's for Ford 302/351's but the same parts fit a Prestolite for a Chevy.
If I was you I'd call Ski Dim just to verify this
If it's a different cap, look at the pictures to identify it.
https://www.skidim.com/distributor.asp" rel="nofollow - link
Posted By: wayner
Date Posted: June-18-2018 at 7:16pm
Thanks, it looks like the mallory stack cap. It has clips that tighten with a screw (but not an actual screw down). I will go to the site to see what the kits look like. Thanks
Posted By: KENO
Date Posted: June-18-2018 at 7:23pm
wayner wrote:
Thanks, it looks like the mallory stack cap. It has clips that tighten with a screw (but not an actual screw down). I will go to the site to see what the kits look like. Thanks |
Looks like part number 1304 from Ski Dim
Your engine tag probably says PRK instead of PKR, just figured I'd mention that
Posted By: wayner
Date Posted: June-18-2018 at 7:30pm
You are correct, PRK. Transposed the letters. Thanks
