tune up kits |
wayner
Groupie Joined: March-20-2010 Location: wisconsin Status: Offline Points: 44 |
Posted: June-18-2018 at 6:25pm |
I cant seem to identify the exact OEM part number for a tune up kit for my 1988 correct craft, PCM 454 ci 330 hp. Engine number is pkr-wr-r10. The distributor cap is a clip type with a screw to hold the clip in place.
Appreciate any direction |
1988 Dominique 454
Wisconsin |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10669 |
If what you have looks like the first picture in the link (which is what I think you describe), then you can use kit part number 1301
from Ski Dim It says it's for Ford 302/351's but the same parts fit a Prestolite for a Chevy. If I was you I'd call Ski Dim just to verify this If it's a different cap, look at the pictures to identify it. link |
wayner
Thanks, it looks like the mallory stack cap. It has clips that tighten with a screw (but not an actual screw down). I will go to the site to see what the kits look like. Thanks
1988 Dominique 454
Wisconsin |
Looks like part number 1304 from Ski Dim Your engine tag probably says PRK instead of PKR, just figured I'd mention that |
wayner
You are correct, PRK. Transposed the letters. Thanks
1988 Dominique 454
Wisconsin |
