  New Posts New Posts RSS Feed - 1981 Stern pole light
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Topic: 1981 Stern pole light
    Posted: June-16-2018 at 8:40pm
Lost by prior owner, I need one.
Is there a direct replacement available?
I've search, but haven't found...
Thx
1994 Ski Nautique "Riot"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2018 at 8:45pm
Thx
Brian,
Are you sure it's not in it's clips under the gunnel?
gt40KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gt40KS Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2018 at 11:38pm
Brian I thought the same .... then I found it when installing my deck lights under the gunnels as Pete said - had no idea it was under there. Apparently the last PO's didn't either because it looked like it hadn't been removed in 20 years
JCCI
1995 Ski Nautique GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2018 at 11:50pm
Check behind the carpeted rear panel in 80-81 as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: June-17-2018 at 8:25pm
Thanks....MIA...
no rubber holders either.
It does appear that they may have been screwed to stringers immediately aft of the rear carpeted panel.
So......where can I get one like original?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2018 at 3:05pm
Aha.....here they are...
The two rubber clips that retain the stern light pole are screwed to the lower backside of the rear panel.
Still need a replacement light pole....
