1992 Nautique Excel. Leaking transmission. |
FootFever78
Newbie Joined: September-22-2014 Location: Cicero, IN Status: Offline Points: 24 |
Posted: October-18-2017 at 3:44pm |
Gang,
I have a '92 Nautique Excel upgraded to a 454. No issues there, but I have noticed that my transmission has started leaking. I wiped the ATF off of the belly of the transmission, used the boat, and then noticed a leak in the attached picture. When you put the boat into forward or reverse with the boat running, it leaks out of the point where the throttle linkage connects to the transmission. See here for picture. It looks like a bad rubber gasket. Question: How hard is it to change this? Do I simply unscrew the linkage and put a new rubber gasket in? Open to coaching/questions. Thanks, Jim |
Jim,
The leak is at the valve spool that controls fluid direction to ether the forward or revese clutch packs. Pull the spool, check it and the bore for burrs and then install it with new O rings. You should be good. |
FootFever78
That's great to know. Thanks a lot. So I can pull that spool out without other internal parts falling out of place? Also, do the O Rings need to be OEM or can I purchase that size at a hardware?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10668 |
If you read the Borg Warner manual in the reference section, it'll have pictures and a description of what to do.
I'd put up a link to it, but if you go there you'll see plenty of informative manuals Top of the page in the same ribbon you click on to get to the forums you'll see reference, just click on that. Hardware store O rings will work. |
FootFever78
Great call - thanks. I found the manual with diagrams, but wasn't able to ID the appropriate description(s). This is as far as I got on the disassembly. Should I be disassembling from the other side? Apologies for my ignorance in advance. First-timer with this...
FootFever78
Update. I figured it out. I will wrench on this tomorrow and shout back with any other questions. Thank you, gentlemen!
Page 24 has disassembly info and page 43, 44 have assembly info.
The pictures show a transmission with no Neutral Safety Switch so it looks a little different but the process is the same. |
FootFever78
Thanks, KENO. As an update, I reinstalled the valve spool incorrectly and broke that and the end cap clip at the bottom. I am searching for parts to complete the install. Photos later.
Did you break the end of the spool valve or just the Neutral Safety Switch cam and the cover?
Page 46 has them shown. |
FootFever78
Sadly both. Sucks, but I am learning a lot about this boat (The Brofooter).which is nice. Any part sourcing suggestions are welcome.
If you put up pictures of what you need, somebody may have some used parts.
I might be that somebody, I won't get a chance to look till tomorrow though. It sounds like the whole spool valve assembly and the NSS parts are what you need from the description |
FootFever78
https://www.dropbox.com/s/65q4infet9dtqtw/2017-10-19%2016.47.40.jpg?dl=0
https://www.dropbox.com/s/wh8thz8lf1hri8y/2017-10-19%2016.14.20.jpg?dl=0 Great! Let me know if these didn’t come through. The cam is certainly busted, but the cap looks fine. Not sure if they can be bought separately or not. |
Hi Jim
No luck on the parts but I'm wondering what's broke on your spool valve? In the picture below which is your valve it seems like nothing is broken, but there's a extra piece of metal jammed in the end on the left side of the slot. If you can get that piece out the spool valve will probably work unless it's broken somewhere else. It looks like you definitely need a new cam though. You could put it together without the cam and the transmission would shift and operate. You wouldn't have the function of the neutral safety switch though and that could be dangerous since you could do things like start it at full throttle in gear and hurt yourself or other people. I'd try Fantastic Finish Marine, in Medina Ohio, they probably have used pieces hanging around Otherwise Discount Inboard Marine probably has the parts EBasicPower also comes to mind as another place with lots of B/W parts. |
FootFever78
This is a better picture of the spool. Is this not a big deal?
Thanks for checking on the parts, I will call tomorrow and get those on order. Really appreciate the help! |
It's still hard to tell the damage to the spool from the second picture, but the only function of that slot is to mate with the tang on the cam so that the Neutral Safety Switch will work correctly.
The shift function and the pressure control function won't be affected and from the pictures it's hard to tell if the tang on the cam will fit without slop. Must have been a case of tightening things without the tang being in the slot |
hoggjaws
Newbie Joined: June-20-2011 Location: Cicero, Indiana Status: Offline Points: 34 |
rumor has it that the bro footer is back on track! well done footfever78!
FootFever78
Well, thanks to a number of guys, but especially Pbrainard, KENO, and Hoggjaws, the Brofooter is back in action! Fantastic Finishes had the parts in great used condition. They installed easily, and off we go. Dry suit time... Check it out!
Until next time... |
Hopefully next time isn't because you forgot to put the dipstick back in the transmission Couldn't help noticing that gaping hole in your movie clip |
FootFever78
well-played, KENO! All is in place now
Is that a 10-17 or 10-18 behind the 454?
I think he's got the 454 hooked up to the original 10-17 transmission. Not the best way to tell but certainly a quick indication is the red ID tag in his picture. I figure that's what caught your eye too Tim Every 71C(10-17) I've seen has a red tag Every 72C(10-18) I've seen has a green ID tag Wondering how it stands up to the "Big Boy" torque of the 454 and how many hours it has with the 454 hooked to it |
FootFever78
It's the 10-17. Not sure on total hours. I do know the 454 was rebuilt last fall, while the Velvet did not require a rebuild. I put about 100 hours on it this year. Aside from the O-ring leak, it's been legit.
Sounds like it's holding up OK to the Big Boy engine
