Carb leaking |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1722 |
Posted: June-25-2017 at 3:34pm |
Took the 78 out today and skied for about hour until the carb started dumping gas out the back. I imagine because it sat for a few years maybe some things deteriorated. Any thoughts on how hard the rebuild is or any thoughts on replacing it with the Edlebrock from national in Florida. If I remember off the shelf for their marine version is under $300.
I am open to suggestions. |
fanofccfan
After looking at their site it appears they offer the Holley as well. Any thoughts on Holley versus edlebrock?
Lots here have been going to the Quick Fuel Same basic as the Holley but with better features like external float adjustment. They even have sight glasses built into the bowls for checking the fuel level. What Edlebrock?
fanofccfan
Pete. NCR-1409 from the web page. I have one on the Marauder and so far so good.
Bill,
I meant to ask why the Edlebrock and not what! I was in a hurry and didn't proof read! |
bb12
Senior Member Joined: March-24-2009 Location: Kansas, USA Status: Offline Points: 355 |
Get a Quick Fuel and don't look back...
1989 Ski Nautique 2001
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10665 |
If it sat for a few years, it probably could use a good cleaning.
Not very hard to do and a lot cheaper than a new or rebuilt carburetor of any brand . Probably about 40 bucks or so for a rebuild kit with all the parts you need. Get the list number off the front of the air horn to get the right kit. You could also try that hack move that Pete referenced from that KenO guy But with a few years of sitting the rebuild kit and a good cleaning is probably the cheap way to go. |
fanofccfan
No worries Pete. Now can I ask why not?
$600 for the quick fuel makes up about 33% of the boats value!😂😂 Ken I may try my hand at the rebuild and I also tried the above mentioned hack.......no dice! |
Lakeview
Senior Member Joined: January-06-2004 Location: Branchville NJ Status: Offline Points: 247 |
Check the list # on the top right front of your present carb-go to Holley's website and find the Model # -this assures the right rebuild kit-I've never heard of anyone replacing the Hollies with Edelbrocks copy of the carter AFB???
Good luck |
Lakeview
1992 Barefoot Nautique 1967 Barracuda SS 1967 Chris Craft Cavalier |
bb12
FWIW I paid $470 for my Quick Fuel. |
Faceplant
Senior Member Joined: July-27-2013 Location: Otter Lake , Mi Status: Offline Points: 405 |
Quick Fuel works great for me .
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2852 |
The 600 cfm can be had for $479. The 650 cfm is $100 more. QF is da bomb! Get it and don't look back.
JQ |
fanofccfan
Bought the kit today. Worked on it tonight and noticed three things. Both floats were set too high, o-rings on feed tube were shot, and someone along the way installed a new gasket over the old gasket on rear bowl. After two hours of razor blade work I know why they slapped a new one over the old, as it came off in pieces the size of a pin head.🙄. Installed it and it ran fine for the few moments it ran in the garage. No leaks so far anyway.
Now ncdoubleup has a quick fuel for sale that you have all been mentioning. |
CRC and Permatex make a gasket remover,works much like a paint remover. Permatex is a brush on,the one I have used CRC,is a spray. I think I'd go crazy with a blade,especially that long! Nylon float bowel and inlet gaskets are really nice to.
The transfer tube and end seals mentioned in
this thread are a good solution for the O ring problems on the transfer tube along with the nylon seals Gary mentioned for the float bowl screws Most of the newer kits these days come with non stick gaskets too, but that didn't help you with the old ones. Paint stripper has become my favorite gasket removal stuff. It softens them up as good as any real gasket remover I've tried. It even smells the same, but you get a lot more for the money That rear bowl gasket is a killer, no other way to describe it |
fanofccfan
Oh I sure thought about a solvent but dint have any so kept on with razor. Not next time. One question I have after seeing how the foots and such work.....what happens to the excess fuel from the pump that the carb does not use? Is there a bypass somewhere or does the mechanical pump just pump what's needed and not build more pressure? Just curious.
The rubber diaphragm in the pump just flexes when fuel isn't needed. |
shierh
I have one built and ready as a spare. Id sell it for 175
We're probably saying the same thing basically, but the pump is designed with a max pressure that it will put out at no flow conditions, around 7 psi is a rough number that varies a little with manufacturers but as long as the needle and seat assembly in the carb can shut against the pressure you won't flood things due to excess level in the bowl(s) |
fanofccfan
Good info. 7psi can sure squirt lots of gas!
fanofccfan
Took the boat out last night and no leaks anymore. Also my buddy pulled up in his 96 yellow ski brendella and thought he should show me how fast the newer boats go.......I quickly dispelled that myth!😂😂
Well Good job I guess that only cost you about 2% or so of the boats value and now you're probably pretty comfortable working with a carburetor |
fanofccfan
Ha! Actually sort of comfy with it. Didn't really go all the way into it. Just the easy parts. Also bought the quick fuel from Jay (ncdoubleup) so as to have a backup if my efforts failed! Boat value is increasing.......
fanofccfan
My repair skills are lacking....it stared to leak again out of the back bowl after sting turns. The quick fuel 600 that I purchased from ncdoubleup should be here tmro. I won't be able to add carb rebuilder to my resume after all.
fanofccfan
Strong turn^^
