  New Posts New Posts RSS Feed - Pot Metsl Repair
Pot Metsl Repair
Colint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Colint Quote  Post ReplyReply Direct Link To This Post Topic: Pot Metsl Repair
    Posted: December-06-2016 at 6:35pm
Anyone ever seen or had and experience with muddy weld?
http://muggyweld.com/pot-metal-repair
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 6:50pm
Colin,
Do you have a repair in mind? If so,what is it and is it truly "pot" metal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Colint Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 6:56pm
It's the side brackets for the 60's split windshields. This isn't mine but a picture from the site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 6:59pm
Colin,
Is your bracket broken or are you just wanting to remove pits? If pitted, a good plater can remove pits. BTW, it's not pot metal but rather a zine die casting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 7:38pm
Wasn't there a 70's rock band named Pot Metal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Colint Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 7:44pm
It's cracked where the rear screw is. Also pitted but I knew the plater could fix that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 9:16pm
Don't know anything about that Chris but when Cousin Donald was just starting out in the early 80's that was his stage name I believe. I'm sure he can fill us in on all the lurid details.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 9:28pm
Originally posted by Colint Colint wrote:
It's cracked where the rear screw is. .
I don't feel the Muggyweld repair will do much for strength with it having such a low melting point. Give it a try but, if you do plan on sending it to the platter, talk to him first since it may not plate very well.
Wasn't a member fabricating some out of brass not long ago? That sure would be the route I'd go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 10:06pm
It's worth a try. Says on their web site that it is plate able. No strength is needed for that part,it is nothing more than a trim piece to cover the windshield end. You can also see how I ran the lower gasket and used the thru bolt to keep it from sliding back from under the trim like the one in the last pic
Post Options Post Options   Thanks (0) Thanks(0)   Quote Colint Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 11:57pm
Thanks for the tips. The pictures help a lot. My window frame is also broken. I have found someone that can weld the piece back on. Those brackets looks great. Hope I can a get that out of mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Colint Quote  Post ReplyReply Direct Link To This Post Posted: December-06-2016 at 11:58pm
I did see the brass ones but that may be beyond what I can do myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: December-07-2016 at 10:39am
Gary,
You are close but back in the 80's when I was a younger Chippendale some of the ladies would call me HOT POCKETS !!!! Then they would lick their Lips. The rest we can not talk about on a family friendly web-site.
When Quinner goes out on Saturday nights looking for a date he calls it POT LUCK . We also can not speak about that on a family friendly web-site.
As far as Colin's question goes, I am a worker of female flesh not a metal worker.
Sorry,
Donald
1968 Ski Nautique, Project.
john b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john b Quote  Post ReplyReply Direct Link To This Post Posted: December-07-2016 at 1:26pm
that's what my friend called his pipe.
