battery amps |
Lake555
Newbie Joined: July-29-2009 Location: Ohio Status: Offline Points: 34 |
Posted: May-24-2016 at 9:07pm |
We have a 91 SN and it looks like we need a new battery. Our current battery is 1000 cracking amps, 850 cold cracking amps. . Is that the recommended required amps for this boat? and does it have to be a marine battery, deep cycle?
Thanks for the help. |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2846 |
Don't get a marine deep cycle battery. A standard automotive battery is what you want. The deep cycle battery is designed for slow discharge...like on a trolling motor. The higher amp draw for starting is hard on the deep cycle batteries.
JQ |
Marty,
JQ is correct about the deep cycle. Many have fallen for them thinking they need them or have walked in to a auto supply and the "associate" thinks they need a deep cycle. Also, avoid an auto starting with the high amps. With the big amp batteries, internal support is sacrificed for additional lead. The lack of support and all the shock our boats give them translates to a very short life.. |
Wow, 1,000 is much more than double what CC recommends. Manual calls for 380. I'd probably shop for something around 400-500.
http://www.correctcraftfan.com/Downloads/1991_Ski_Nautique_Owners_Manual.pdf |
shierh
Use the highest amp battery that will fit. never be sorry. also i found that it is best to try to do some vibration isolation. I found some medium density silicone rubber thats 1/4 thick and put under the battery, cant hurt.
shierh
As a foot note, i agree, dont get one that has too many amps in a small package. Largest case that will fit in battery box
you're awfully confusing
Just use the old one out of your car,someone will have a tool box you can use which will open up a world of other opportunities.
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6147 |
Ehh Pete, I have an 6 ish year old 1000 amp auto battery still in perfectly working order in my 86. Also a 3rd summer 1000 amp in my 85.
I prefer extra amps they have always treated me great and don't leave me stranded at the sand bar if I've been cranking tunes and sipping brews. Group 65 is the correct size to fit into the SN box and let the lid close. |
Zach,
All I can say is you have better luck with batteries than I do. I went through 3 1000 amp Exides in 5 years in my X55. Then I did some research and found out about the plate support being skimped on for more lead. Guessing, the battery that's in it now is at least 10 years old!! |
I do like the suggestion for a little shock absorbing material under the battery. I have some extra neoprene that I may try. Thanks for the heads-up.
JQ |
phatsat67
Pete, I wouldn't recommend an exide to anyone. I went through 1 a year for 4 years until I got tired of returning it under warranty and bought the one that's still in the 86. Don't think it was your batter too large just s terrible battery to start with.
We've had good luck with NAPA legends. 600-700 CCA would be the minimum I would by, unless I had no other choice. We've got a 350 CCA in the Mustang and it doesn't have much back up cranking power.
OldBrewer
Newbie Joined: April-26-2016 Location: Lake Helen, Fl Status: Offline Points: 27 |
I am installing a second battery with a selector switch. I always had two batteries on any boat I owned. Glad to see I don't need a deep cycle battery. I hate Murphy's law.
Yuengling
Ever since I had the bad Exides, I'm running the Legends too without any problems. |
dave12gauge
Newbie Joined: April-06-2015 Location: California Status: Offline Points: 34 |
On our farm we have switched to AGM batteries. AGM= Absorbed Glass Mat. You get what you pay for. These are NOT Gel batteries like Optima. They do not need special chargers. You will find that the "dual purpose or marine" battery" is both a start and deep cycle. The technology has been around for a long time (I think the 80's, they went into tanks). Our parts house carries Exide on the shelf, and a few Deka's. We started to use the Exide AGM but we were getting old batteries from the Exide warehouse. (older than a year). We now only buy Deka AGM batteries for everything. No more adding water, if i forget to charge a battery "once a month" its not a big deal because AGM does not discharge itself (its very slow). Come to think about it we don't have corroded battery cable either. AGM is made for harsh conditions. They last a long time. Do a little research and you will see they are a much better battery.
When it comes to CCA, act like a farmer, "if a little is good, more is better". (same for grease, silicone, tape, Horsepower, most things in life.) |
We've clearly disproved more CCA is better for regular lead-acid batteries in our boats.
David,
It sure sounds like you go through plenty of batteries! What do you contribute that to? |
dave12gauge
Very true. My thinking is getting physically the largest battery that will fit. The dual purpose battery, in my thinking, would have medium sized plates. Thin plate batteries have high CCA because they have more plates, deep cycle has thick plates and less of them (not made for starting and engine). So dual purpose battery (marine/RV) with medium thick plates would hopefully be made for harsher conditions, we don't need high CCA because "Cold Cranking is at o*F. I doubt too many of us are using our boat in that cold of weather. |
dave12gauge
We do go through plenty of batteries and we contribute that to about 35-40 battery on our farm and toys. And we have had all different brands though out the years. Interstate, Napa, Excide, Deka, Optima, Wal-mart, etc. There all ok, some better than others. We have machines that are called shakers, they literally shake themselves to broken welds. We watch the water, keep them charged, harsh conditions, its 100-110*F when where using it. OEM battery on another machine (no vibration) Napa Legend failed in 3 years. Diesel deep well engine came with high dollar batteries (forgot the brand) failed about 3 years. I went through 3 Interstate batteries in my truck under warranty, the AGM batteries are 4-5 years old and still going strong. Tractor with good sealed battery went out in about 3.5 years. When I bought my boat, the optima battery was almost 10 years old. There are better mouse traps. My Dirtbike has a Li-ion battery and its 2 years old, so far so good. Batteries fail because of vibration, lack of water, heat, cold, not being charged, and being built cheap. etc. I'm also not perfect when it comes to exact mainatiance like the manufacturers want me to be. AGM battery gets me a better mouse trap. |
