Overheating on the river but not at house? |
MarauderMatt
Newbie Joined: August-05-2015 Location: Corpus Christi Status: Offline Points: 31 |
Posted: August-23-2015 at 8:38pm |
Ok so when we are in th driveway with water hose connected never gets over 160 degrees. I just bought the boat and replaced water impellar. Thinking she is good to go, take boat out at river and within 5-10 minutes overheated. Where do i start and what else do i need to change out? I own a 1976 Ski Tique. How can i test to make sure the water impellar is priming the system out of the lake? Any help would be greatly appreciated. Trying to get this running right before season is over lol
71CCMartinique
Groupie Joined: June-15-2012 Location: Ohio River Status: Offline Points: 55 |
Is it possible that the t stat is giving you trouble? Mine opens about 165 degrees.
....and the adventure continues.
MarauderMatt
if it was the t stat woudnt it overheat in driveway too?
How did you hook it up to the hose at the house?
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
Bucket test.
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
MarauderMatt
can you explain the bucket test |
MarauderMatt
there is a slight drip of water coming from water impellar pump. but its not that much and its been leaking at this spot for about 2 years with no issues before.
MarauderMatt
plugged the water hose into a fitting rigged up, opened the valve
Here is the bucket method,disconnect the intake hose and 1- either connect a longer hose and put into a bucket or 2- put a fitting into the side of the bucket and connect the hose to the intake hose. This way the system is not pressurized by the house pressure,the engine pump must do the work just like at the lake. This is why I asked how you hooked it up at home---
When you connect it up like that you dont even need the raw water pump! That is why you see water leaking too,any leak with pressure will be sucking air when under suction. Take a glass of water and a straw,cut a hole in the straw an inch higher than the water and try drinking it. That is what your pump is trying to do,thats you at the lake. If you were able to pressurize that straw,some water will leak out but the engine would get enough to keep cool while it ran,thats you at home on the hose. |
CrazyCanuck
Sorry. I should have elaborated. Gary caught it.
On my boat, I unhooked the hose from the oil cooler and then that gave me lots of slack to put in in a bucket of water. You want to see if the impeller is actually drawing water in..... |
MarauderMatt
since the Raw Water Pump has a slight leak, do i need to replace the whole unit? is so whats the part number? i hear they are expensive
CrazyCanuck
Where is the leak coming from? If from a hose connection then no, but if its the shaft, then yes maybe....
Can you post a pic of what you have? |
MarauderMatt
looks to be coming from a tattletale, maybe from the shaft? ill have to take a closer look when i get a chance
spiralhelix
Senior Member Joined: August-06-2014 Location: IL/WI Status: Offline Points: 496 |
The RWP can be rebuilt. Pretty sure Gary has done them. A new one is pretty expensive. I believe I paid upwards of $400 for mine.
im sure you can get parts from skidim.com, marinepartssource.com, nautiqueparts.com, or n3boatworks.com Most of them have 10% off with codes or CCF membership. |
+1 |
MarauderMatt
well, did the 5 gallon bucket test and found the pump was blowing water out instead of sucking it in lol....flipped the pump around and sucked down that 5 gallon bucket of water in seconds!!! My question is there is a flat head screw on the pump that was on the outside where it was visible. I flipped that pump over 180 degrees now the screw is on the inside where u cant see it. But for what ever reason is sucks great now?
That screw holds the cam in place inside the pump. Placement of the cam determines which way the water flows thru the pump. The position of that screw facing in or out depends on the rotation of the engine. Facing in for a left hand engine,out for a right hand engine. Your engine is a lefty which is a whole nother story--- glad you figured it all out.
Careful Gary, you're assuming he has a PCM. Commanders and Escorts were available in the mid 70's and they put the pump on the other side of the engine. Pictures woul help here.
Oops I did
MarauderMatt
how do i tell if its a lefty? and if it is then why is that a whole nother story? |
MarauderMatt
pump is on driver side of engine, i believe its a PCM engine, |
Post pictures of the engine and prop.
MarauderMatt
old pic but should be able to tell if not i can get more later when i get off work |
MarauderMatt
RWP pump is in orange bottom left side of pic
baitkiller
Ill leave the fuel line and filter for you guys.
Not good. Post a pic of the prop.
