Best place to buy CPES? |
seacamper
Platinum Member Joined: June-24-2010 Location: Florida Status: Offline Points: 1056 |
Posted: January-13-2015 at 1:04pm |
Hey All,
Where is the best place to buy CPES?? Thanks Tom |
1980 Ski Nautique Boat Bar
1988 Mastercraft Tristar Open Bow 1988 Mastercraft Tristar Closed Bow 1969 Seacamper Houseboat 1986 Harris Pontoon 2004 Seadoo GTX SC + Flydive Xboard 1999 Adventurecraft |
SNobsessed
Have you considered making it yourself? 75% Epoxy resin + 25% Xylol. It has worked well for me.
Orlando76
I've bought it from rot doctor in the past. I think it's expensive no matter where you buy it from. Next time I re do my seats I'm going to debate not using cpes again due to the simplicity of the seat reconstruction vs expense of cpes. Idk, we'll see how long it lasts this go around. On floors and stringers, no doubt I'll bite the bullet and use cpes.
Making it yourself by thinning down regular resin is certainly an option but there is one major difference with the rot dr's product. It is made from wood fiber instead of an oil. That is supposed to make it more compatible with the wood. Whether this makes a difference with our using it for a water proofing is up in the air.
If you do buy the dr's, Jamestown distributors is where I get mine. |
backfoot100
+1 I can't say as I'm an expert but when I redid my floors, I used Rot Doc's CPES and epoxy resin. I've seen all the posts about mixing it up yourself, but with any epoxy, you have to consider the ambient temps and weather conditions before mixing. I didn't want to have to deal with that with my first time working with epoxy. Rot Doc's CPES and epoxy resin was very easy to work with and easier to mix. I can't complain with the results to date either. 15 years and my floors are as solid as the day I finished them. It was expensive but I wouldn't hesitate to use it again. |
Eddie |
seacamper
Rot Doc it is!
Tom |
bkhallpass
I use the product manufactured by Smith and Company out of Richmond CA. They actually own the trademark to the term Clear Penetrating Epoxy Sealer, and therefore that is what the product is called.
It's available at Jamestown and others, but luckily for me, my brother also carries it at the Paint Store he manages. Simple to mix and seems to work well. BKH |
Livin' the Dream
seacamper
So I guess that the Rot Doctor sells Smiths CPES, but there is not a Rot Doctor CPES?
Rot Doc |
audiodude
Senior Member Joined: November-19-2012 Location: Badin Lake Status: Offline Points: 299 |
When I did my outboard I got my Epoxy from Aeromarine you can get a 6 gallon kit for $340.00 4 gals of resin 2 gals.hardener. They list on ebay
1989 Correct Craft 2001
In the words of Milton Berle: "You can lead a man to Congress but you can't make him think" |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21138 |
Us composites is cheaper and proven. When they sell a 5 gallon kit, you get 5 gallons of resin plus hardener.
Orlando76
Why do I not see CPES at US Composites?
seacamper
I was going to ask the same thing. I probably need to put them on my "call list". |
To my knowledge, they don't sell CPES. My comparison was vs. epoxy cost from Aeromarine that was mentioned.
Personally, I can't see paying 2-3x the cost of epoxy for someone to dilute it with (much less expensive) solvent. I don't have long term results to point to (yet!) but regular epoxy resin thinned with a bit of xylene wicks into wood very well- and I bet holds up just as well. The goal is to get the epoxy penetrating deeper into the wood to plasticize it, after all. If you're looking for the best solution available- cost be damned- then skip the wood altogether and go composite. Spending lots of extra $ trying to turn a budget material into something it's not just seems counterintuitive... Wood hulls notwithstanding, of course. Just MHO. |
Orlando76
In hind sight, that's how I feel. I spent way too much $ trying to bullet proof wood in something as simple as my 70's model seats. I was really impressed with the rot dr cpes and how it plasticized the wood. Screw retention in composites is a concern of mine, I need to study up on it better. As a side note I have a lil bit of wood and epoxy and cpes left over that'll prob go bad before I get to use it again so I'm gonna make a few samples of wood vs cpes wood vs epoxy wood and throw it on the ground on the side of my house that never seen light and is always wet. We're talking extreme brutal conditions tgat will test anything. I'll post results in a year lol. |
I always have a stock of CPES. There are times when it isn't used for more than 4 years and it's still good. |
