  New Posts New Posts RSS Feed - Vintage Speed
Vintage Speed
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2014 at 12:52pm
Actually there is a good prop shop just north of Green Lake in Red Granite, WI. It's old school so not a place to take a CNC prop. Place is called Luft's Prop Shop (really old school - No website) phone:(920) 566-4575
There is also shop here near Racine called Props Ahoy. He is a bit expensive, but has all the ACME blocks and is one of the certified ACME repair shops - costs about the same as sending it back to ACME. He does really nice work. Not sure what he charges for an older style.
vernonfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vernonfarmer Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2014 at 12:54pm
Reunion page here doesn't show a date for Green Lake 2015. Is there a date set? Would very much consider attending if it doesn't conflict with anything already on the schedule.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2014 at 1:01pm
Usually the 3rd weekend in July. The planning guys are talking about setting the date sometime in January. Watch this thread for the announcement Green Lake 2015
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2014 at 1:16pm
Northside prop outside of Milwaukee is another great shop. Many of the vintage ACBS boat owners have have very good luck with it. I don't believe he has a web site but if you google it, his address and phone # will come up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2014 at 2:02pm
Dwell can be set with the feeler gauge.
C'mon Pete, you know the deal!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2014 at 5:24pm
Tim,
Yes, a dwell meter is better but understand we are talking about vintage flat heads that rarely get over 3500 RPM. I know of no one who pulls out the dwell meter on a old flat head. In fact, you would find it difficult to find dwell spec degrees in any old manual. The practice of using a meter didn't start until the late 50's when the higher RPM V8's were marinized.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2014 at 5:27pm
So unless your working on an old GM engine which had dizzys that could be adjusted with a tool while looking at a dwell meter, how do you adjust these boat dizzys. Keep pulling the cap after looking at the meter and changing the gap until you get it right according to the meter? What a PIA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2014 at 6:08pm
Yep, that is what I used to do. However, if you are good at setting the gap with a feeler gage, it doesn't take many iterations.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2014 at 7:09pm
Correct. I agree.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2014 at 12:24pm
Correct... Adjusting the gap will change the dwell. You can measure it with the distributor disassembled... It's not very painful.
Pretty sure feeler gauges are used to set the gap, Pete! ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2014 at 1:06pm
Only if your one of the guys with those new fangled plastic boats,if you want to keep it original you'd use a matchbook cover to set the gap
NautiqueNut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 1:49pm
Vintage Speed, here is one for you all, a 1962 Higgins port royal that was junk converted to a usable ski antique before we ever herd of the word correct craft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:40pm
Every time i see a Higgins like that it seems to reinforce the notion that the 1st gen SN was VERY closely related.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:47pm
Vintage Speed, This all took place in 1970-1975. My boyfriend and I loved to waterski, he loved to barefoot. We needed a fast boat and he made the one I have posted. Sorry I did it wrong but I will try again next time to get it right http://www.correctcraftfan.com/forum/smileys/smiley2.gif
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 2:53pm
You are so right about that! This Higgins was lowered 9"-10" off the deck , however the design was near the same as the first generation Nautique it is incredible.
62 wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 62 wood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 3:07pm
Wow, that does look like a first Gen SN!
This "carving" was done in the 70's? Pretty cool!
Here is a pic of my "stock" hulled 62 Higgins Port Royal...
64 American Skier
62 Classic..
73 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 3:16pm
Lisa, welcome to CCF! Is the boat still around? What was the engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 3:39pm
Iam sorry to say that it was sold some 39 years ago, then we had know idea what the future would be. If I could go back in time we would never have sold that boat it was a one of a kind. But then we bought a 1972 correct craft Skier with the 302 Holman Moody. This was a nice boat. The old Higgins had a 327 gray marine v8 it would pull 48mph. Time changes everything, for me its great to remember the old days...
http://www.correctcraftfan.com/forum/smileys/smiley19.gif
