Project 67 Mustang |
Post Reply | Page <1 234 |
Author | |||
ryanibanez88
Senior Member Joined: July-22-2011 Location: Midland TX Status: Offline Points: 219 |
did you have to cut it or us the jaws of life
Ryan
1997 Ski Nautique Midland Texas |
Well I think you know the head answer, might as well get yourself a set of gt40p's. Head work is expensive I have as much in a set of standard heads that a local shop did as I have in my,at the time,brand new P's with larger valves.
Agreed, those heads are anchors now.
Might want to edit the title of this thread now that you've confirmed the boat is a '67! |
dochockey
Where does one go for a set
I've tried to change the title and my profile with no success |
1989 Teal Ski Nautique
halfnelly
Senior Member Joined: January-14-2013 Location: Maitland, FL Status: Offline Points: 253 |
I know the block has 289 stampings, is it a 289? If so, consider having the P heads planed as well since you'll lose quite a bit of compression with the short 2.87" stroke. The old 289 castings were only 54-56cc chambers. GT-40P's are in the neighborhood of 60cc stock. |
dochockey
This is where I need lots of help is there a particular brand name I should be looking for ebay, summit should I buy assembled , while I'm at new piston rings etc
scootdogydog
Pete, I'm going to post a picture of the ski to I picked up near WL. The Fram filter is still in tact :) |
dochockey
So i need some help it turned out the motor was toast
need some recommendations on a replacement ? |
Rebuild the original. |
dochockey
The block is gone
Get a junk yard block. |
