  New Posts New Posts RSS Feed - ‘Project Tique’ photo thread
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: November-22-2013 at 7:01am
Brackets may not be perfect to you, but they d*mn sure look good to me!
Nice work Graham!
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2013 at 8:12am
I see my list of Graham made parts is getting longer... nice brackets
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
gR@HaM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: January-02-2014 at 5:49pm
Well it's been a while, I had some time to spare today so managed to make a start on the observer seat foam:
I found these to be very useful for temporarily holding the pieces together
Wing nuts to allow the seat to be switched to forward facing if I ever feel that way inclined:
Next step to work on the skins, I'm off work till next week so hoping to get a bit more done over the next couple of days..
'82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2014 at 7:45pm
Have cut the patterns out and made all the lengths of welt, mostly a case of putting it all together now
'82 Ski Tique
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2014 at 8:41pm
This is too cool! When are you going to come to Iowa and give us lessons?!
flipflop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flipflop Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2014 at 9:32pm
Looks great. I really like the blue and good job with the upholstery. Adding piping and top stitching really makes a piece look great. Did you have any special attachment to work with the piping?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2014 at 5:59am
Nope just used the machine as it was when i borrowed it and ran as close to the rubber cord as I could, all pretty straight forward
'82 Ski Tique
juniorwoody View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorwoody Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2014 at 9:22am
Should find the Starflite seats easy to do after doing these Graham. It is the time of year for these inside projects.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2014 at 3:11pm
Mini update, had good weather today so managed to fit those platform brackets.
Here they are finished off, drilled and tapped m10 threads for the transom bolts which needed to be countersunk, also made up some backing plates:
Fitted them to the boat using plenty of 5200
And with platform on top:
'82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2014 at 11:50pm
Graham - I think you will have an awesome boat when you get it finished!
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2014 at 7:41am
Looks good Graham, are you going to add some kind of lock pin/R clip to stop the platform lifting up and down in the water/waves, as it’s a solid platform and will won’t to lift more than an open slat type... could mark your new gel !!
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2014 at 2:53pm
Thanks. Yes, was thinking the same Roger just not worked out the best way of fitting one yet!
'82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2014 at 3:11pm
Have a look at these, think it's the easy way to go... not all S/S but change the nuts out for S/S so only the body and spring are coated steel,there may well be a all S/S ones somewhere but at the cost £2.24 each I would buy a spare set..just tap one each side of the boat into the slide mounts.
Index Plunger
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2014 at 7:54pm
Wahey thats way better than anything I've come up with!!
Wouldn't be all that bad if I can't find stainless ones could probably get them phosphated in work
'82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2014 at 8:44pm
Index Plunger
Roger,
You must have some pretty long arms to pull both plungers on both sides at the same time!
Look for these:
They 1/4 turn lock and are available all stainless. Over here, good old McMaster has them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2014 at 7:34am
Index Plunger
Roger,
Look for these:
Morning Pete, I see your keeping me on my toe’s...we have pull and turn here too just not found all S/S yet...but we do have specialist tools for short arms if this type is used...in this case wood is best.
Hope to see you and the Atom at SJRR/Sunnyland.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2014 at 11:31am
Hey, that looks just like the special tool that I use to keep engine valves from falling down into the cylinder when air pressure is released as I take the springs off while the heads are on-engine.
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2014 at 12:43pm
Hi Art, I like it... yes they are a multi tool...can be found hanging on many manual pull out choke knobs.
Hope you are well... see you in March for a catch up.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2014 at 1:15pm
Here we are Graham,try these companys,
Elesa
or
Rencol
I like the Elesa, these should be low-ish in cost #GN.36432   description code GN 8221.1-5-C-NI all in S/S.
Choose what floats your boat.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: February-06-2014 at 4:09pm
Thanks Roger good find have ordered the Elesa ones
'82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 8:25am
Graham, Glad it was of some help...they look to have a good stock I have bookmarked them, have a look at the rest of their site I see they have lots of different collar rings as well that may work for your new shaft.
Roger.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 10:52am
Shall have a butchers, I already have a shaft collar on order but am after some good quality hinges to allow the observer seat to flip down
'82 Ski Tique
leetudor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2014 at 12:31am
What is the overall width of the platform plates?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2014 at 12:57am
Lee,
You may want to be more specific as to which dimension you are looking for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2014 at 3:44am
Of the plates that mount to the boat that allow the platform to side off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2014 at 9:13am
Lee,
Measure the width of your existing bracket, add 1/4" for clearance and then add 1" on each side for the flat heads that hold the assembly together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gR@HaM Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2014 at 9:35am
Yep best measuring your brackets, I used 100mm wide stainless bar 10mm thick
'82 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-11-2014 at 4:47pm
So my bracket is 2.5" wide, would 5" wide bar be too wide?
