Mission: You Wanna What? [LOL] |
Post Reply | Page <1 4567> |
peter1234
dont forget on any tri power conversions you need to change base plates or plug all idle passages in them . you dont use air screws on anything but the middle carb. also throttle plates are different on tri power front and rear.
I realize that, it's a common problem. Rh rollers did not exist for any of the vintage engines. Roller conversions can run $1500-2000 once you consider the new lifters, valve springs, etc. A rh cam itself (custom blank ground to your specs) should only be in the $750 range, at least that's what it cost for our 454- and that's what I've seen quoted for a 351w as well. An off the shelf lh roller would be ~500 less. The other costs are the same whether rh or lh. Starter, distributor, prop, etc, if required to swap rotations, will erode that $500 savings.
Tonali_III
Senior Member Joined: August-30-2004 Location: St. Louis, MO Status: Offline Points: 412 |
Tim, The problem is with the blank. I ordered a cam from Lunati a while back and slipped in my RH 440. The oil drive gear is cut on a different bias and if you set the cams side by side, it's like they're in a mirror. Unfortunately, there are no rh blanks available. |
1974 Southwind 20
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6752" rel="nofollow">1972 Mustan |
Tonali_III
Zach, I talked to a Holley TEch guy and he told that the 2300 series marine carb is a different animal. Not just the 'J' tubes and jetting, but the passages internally are different. He would sell me rebuild kits for the marine carbs(if I could come up with numbers...I did ), but as for setting an automotive 2300 up for marine, he recommended against it. So, are there REALLY any differences internally between these carbs, besides the centermount and the front/rear mount? |
1974 Southwind 20
What joe said. I'd be surprised if the rh roller was $500 more than a lh roller conversion, especially once you consider all of the other components that would need to change on your current rh engine.
oldcuda
Senior Member Joined: June-22-2010 Status: Offline Points: 474 |
Had a stock 440 in a 56 Chris Continental 23 ft with a 16x16 3 blade and it would effertlessly jump right on plane even with six aboard.72c 1:1 thought it was going to be too much prop but the 440 had plenty of low end power.That drive line ended up in a 1927 22ft Chris tripple(sorry purists)owner was tired of putting head gaskets on original Chrysler Crown.Boat had a 3/4in epoxy bottom and was reinforced still there today as far as I know 20 years later.
You'll shoot your eye out...
It will be interesting to see how those 440 source heads work, they are at a price point where I would find them preferable to putting any money into stock heads for an upcoming RB build I have planned. I would tend towards the dual quad setup as that was a common chyrsler marine offering on the RB's. Left vs Right certainly effects resale and cool factor, but does also increase the degree of difficulty somewhat. What transmission is on there now? Is it really a paragon? I would expect a borg warner 72 series back there, which would of course be usable after rotating the pump. As for handling on that barge.. don't know that I would bother switching just for handling purposes, maybe a little less lean but it would be a stretch to be too worried about it. I dont think the pcm trans would be worth the effort either, it would likely survive but the gear reduction combined with the torque the engine could produce would be pushing the limits of a 1 inch drive shaft.. so you just start throwing money at the thing and youll find your prop choices arent that plentiful either. Roller cam is a no brainer.. remove any ideas or worry about getting it out of the water because you have a "top end" engine/cam/intake. Trying for a stump puller is the road to wasted money. Its a boat, by its very nature it takes less torque to move through the water at lower speeds than higher speeds, combine that with it being a big block stroker and there is no chance your are going to end up with a hole shot that is anything less than spectacularly improved over what it is now. What are your thoughts for ignition? |
This may get complicated due to having to swing a larger diameter prop. Strut? Log? Shaft? Same goes for the ZF. |
phatsat67
I have a bunch of 1.23 transmissions at the shop. Don't know if you could mate one up to the 440.
Press your own j tubes into the Holley 2 bbl. demon makes six pack set ups. Might check if they offer those in uscga. I love the speed demon on my car. |
Bruce, Yes, I don't think it wasn't until the early 70's when I seem to remember the carbs being marine rated. |
oldcuda
I was curious if a Hurth reversing trans would help/solve the handling issues with a lefty.Plus with the down angle you can get more under the hood.Tim is right roller all the way I think.The money you save on a reg roller for a 440 would buy most of trans.I am still kicking around putting dual quads on my 511 BBC just love multi carbs and the budget is totally out the window why stop now.
Tonali_III
Perfect!!! This is exactly the starting point I needed!!! Thanks, Zach!!! Thanks! Thanks! Thanks! You just made the "Must Consult" List with Woody and Art Cozier. |
1974 Southwind 20
Tonali_III
Jeez, she sounds Swwweeeeet! Can't get enough of that sound! |
1974 Southwind 20
Tonali_III
Zach,
My experience with an Edelbrock STR series is with the STR 10. We were looking for an intake for our small block (L84, 365hp, 327cid) modified door slammer drag car. We started with a 1973 Chevy Nova, put it on an acetylene diet, and built a 1964(?) L84. My partner was tempted with the STR 10 during a visit to our local speed shop (Platzbecker Speed Shop). He knew his wife was going to kill him. He bought it. We spent the next few months trying to get this thing dialed in. (We did not have access to a dyno back then.) No matter what we did, we could not get that STR 10 to perform as well as a single four barrel. After I moved to St Louis, I discovered my partner finally got the car into the low 11's. But not after a lot of work, research, and cussing(if i know Mike, ALOT of cussing ) Unfortunately, I have a jaded attitude toward the Cross Ram intake. |
1974 Southwind 20
Tonali_III
Anyone who has not had a fire yet. AND is willing to risk having one. |
1974 Southwind 20
Tonali_III
Thanks, Zach. Actually a 6 pack was the first candidate. I was at the Marine Engine site and found that the 6 pack marine carbs were a rather...RARE animal. And converting a standard street 6 carb was way more liability than a shop wanted to accept. Tha's why I decided on dual quads. Tell me more about this Cross Ram to Wedge Head setup. I have always been told that it was a mismatch. Contrary to the unspoken comments, I am very interested in learning as much as possible about this. I do a lot of research before I plunge into a project, and continue that research as the project progresses. And, yes, I can be trained. I have a few past flight instructors that all agree. |
1974 Southwind 20
How many vintage engines actually have marine carbs?
phatsat67
Read this build
Basically the same heads and stroker kit you are wanting to use. That motor is a serious low rpm power producer. |
phatsat67
Thanks Pete!! Tony I also think you are a little to scared of the cross ram power producing rpm. They aren't quite as high strung as you might think. Keep in mind the super stock cars in stock configuration were being shifted around 5800-6000. And going through the traps. At 6500 depending on factory gears. The earlier engines had as much as 13.5 to 1 comp. the factory camshaft was very conservative. The factory max wedge exhaust manifolds were like headers in that they had longer tubes and were designed to scavenge cylinders. With an aggressive camshaft swap they took full advantage of the header like manifolds and power output would go up drastically.
With your big inch stroker and good head flow I think it will be easily possible to more than eclipse your 500 number well before the 6000 rpm mark. I also think that the proven 6 bbl application would be your best choice. But a big block with a cross ram would be soooo cool. Can you get flow bench data from 440 source on those heads to aid in camshaft selection?? 440 cross ram Pete, that's another thing I was going mention is I'm not sure there is a marine rated 6 bbl carburetion that would work. The cross ram would probably be easier to tune. 6 pack cars are quirky so most people just but bran new carbs instead of rebuilding. |
Zach, What marine rated 2 barrels would you recommend? |
Tony,
Listen to Zach's suggestions. He has been around the Mopar's for a long time. He is the #1 member on site with the Mopar knowledge. |
phatsat67
If you're thinking of that eddy manifold why not go with a traditional 6 pack set up. That is a dual plane intake that makes wonderful low end power and pulls hard to 6500. You'll also have more than enough cfm coming at 1350. Plus you can putt around on the middle mechanical carb and when it's go time the outter vacuum carbs will come in to play.
Tonali_III
I thought the intake mounts were a little different and the ports didn't quite match up. What about width? Will a Cross Ram fit under a CC doghouse lid? I can custom fab a doghouse if I need to (I will need to if I go Hilborn.). Would you go Mopar Performance Cross Ram or Edelbrock STR14? |
1974 Southwind 20
phatsat67
I'm trying to stay old school !!!!
phatsat67
The only difference in max wedge heads were the closed combustion chamber like the 1967 440 hp heads only availiable on the gtx and rt. ports remained unchanged. The crossram will produce power. You could produce 500 with that stroker kit below 6000 rpm..
Tonali_III
Zach, Boy I need to stay informed more. I just found that the Angola store was sold off to N3 where you work.
The CC "old school" dealers are really starting to go away. Shame! I lot of good talent is disappearing into the night. |
1974 Southwind 20
Tonali_III
Impressive build Zach. Are part of the MidAmerica guys I used to see at the St. Louis Boat Show a few years back? I remember showing up wearing my N.O.A. T-shirt and hat and received the Royal treatment. They knew I was serious. |
1974 Southwind 20
Tonali_III
Just checked out your YouTube videos. Impressive boat, Pete. |
1974 Southwind 20
Tonali_III
MMM, I don't know. According to the Mopar catalog: Mopar Performance Catalog (see P. 56) These Cross Ram Intakes require the use of Max Wedge Cylinder Heads. And still the very nature of an underhood tunnel ram, the RPM numbers (3,500 - 7,500) don't fit a marine pleasure boat profile well as it it designed for the Super Stock Drag Racing world. Also, there are fixes for the system: STR 14 Box Flow Dam Fixes The STR 14-6 looks way COOL, but it has its own little problems: Str 14-6 In the end, the headache of a Cross Ram in a marine application introduces too many variables that are easily avoided and handled by going dual quad high rise or Hilborn Injection. And I am not sure about Hilborn Injection. I still have a call in to them about my application. |
1974 Southwind 20
phatsat67
They will fit any bb Chrysler head..
