  New Posts New Posts RSS Feed - '78 with 351 raw water pump replacement
yamaha06 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yamaha06 Quote  Post ReplyReply Direct Link To This Post Topic: '78 with 351 raw water pump replacement
    Posted: June-10-2012 at 9:41pm
Purchased Sherwood RA057007 raw water pump--how does it mount. If could pull pulley, think it would fit original bracket. Is there a special bracket I have to purchase to make it work? Any help would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2012 at 9:48pm
Sam,
Please tell us more. Why the replacement? What was wrong with the old pump?
Welcome to CCfan. How does it mount?? The same way the old pump does!! We want and need pictures!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote yamaha06 Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2012 at 9:54pm
Shaft on old pump leaking. Told since original pump no longer available, would have to update.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2012 at 10:11pm
Sam,
Engine? Who told you the pump was no longer available? Depco pump?
BTW, bearings and seals are off the shelf at a power transmission distributor. We still want more info and pictures!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote yamaha06 Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2012 at 10:18pm
Already purchased new pump. Trying to find out how to mount to original bracket without pulling pulley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2012 at 10:57pm
Sam,
Number 1 is we need to know who is giving you the info about needing to replace the pump????? You are not answering the questions being asked!
PICTURES!!?? WHO IS TELLING YOU NEED A COMPLETE NEW PUMP???
Per previous post - can you read????? Sorry but it seems you can't??
Sam,
