Marauder 19 |
Post Reply | Page <12345 10> |
Call
peter1234
I would call the boat yards surrounding larger lakes . N.E winnip...( i can never do that one..) vermont lake champlain . coastal maine has an old plywood boat in every boat yard. if you find any 409s let me know
peter1234
new hampshire craigs list. 1983 century ski boat with 440 inboard , dont know rotation but its 650 for the whole boat and trailer
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1739 |
Thanks for all the help. I will try those options. Took a few more pics of the turbos and such. Looks like they would be big project for a "toodle around a small lake boat". Not sure of that route but I thought some might like to see them.
fanofccfan
they make them (the engines) spin both ways. what makes them spin left or right? can a left be made to spin right? or are those really dumb questions..... and should i get ready to take a real beatin' for even suggesting the thought?
BuffaloBFN
You're breaking my heart. |
BuffaloBFN
I don't think you want to change drive rotation if that's what you're asking.
fanofccfan
i wondered about that confusion when i asked. i will edit. what is different with the motor?
fanofccfan
heartbreaker.... lovetaker....i just said "not sure"
probably the only way you could use a lefty would be to put a 1.23 pcm in there which would allow you to keep the right handed prop, although your flange coupling is a 4" and you may be on the edge of capacity with the PCM trans, although those too are used behind the 502 pythons. you would need to change the 5" flange on the prop shaft to a 4". very feasible and not detramental to the originality.
did you measure the prop shaft? is it a 1 1/8? |
seeing the set-up in more detail, it would be ashame if those ornaments didnt go back in the boat....i bet she would be a whistler, no better sound than some turbos' spooling up. you dont have to go all out and try to make a speed demon out of it, by propping the boat correctly you can stay in the guidelines of a normal weekend ski-boat to serve your purposes
fanofccfan
eric---i love your way with words---
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3893 |
I believe the Cam is special on a RH Motor. The Distributor has a different Gear for the RH Motor. Also, the firing order is very different. The Cams are hard to find, but may can be special built.
I hope this helps from a Shade Tree Mechanic. Donald |
if you got the moola, anything is feasible
the good ole boys here on the site would put 2 chrome stacks out the side of the engine box to suck some air
another good sourec for a 440, would be decrepit motorhomes, alot of companies used them
fanofccfan
I have a 440 sourced but it is not Maranized and it spins regular automotive rotation.
That auto 440 is worth it's weight in scrap iron to you and not that much more you need the marine bits which are much easier to get all at once than one at a time and since they will come on an engine it is worth waiting to see the condition of that engine before investing in relatively simple to find auto 440's . Long run it will be a lit quicker and cheaper to search out a complete marine rh 440
peter1234
try the dual engine plywood boats you can at least get the right rotation and some spare parts to boot
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6108 |
peter1234
thats a half hr from me if i can help you
fanofccfan
peter
if you would be so grateful and want to check it out that would be great. let me know what you want me to do and lets go from there. rotation might still be an issue. price is reasonable enough. thanks and just tell me what to do from here. bill larry thanks for the help and link. |
DrCC
Well that was quick!
I was thinking about making the 3rd phone call. Or almost getting ready to suggest buying a new engine for the '96 and installing the GT-40 in the Marauder. |
peter1234
even with freight charges it would prob be worth it . refresh me you need a left rotation?
peter1234
sorry i just reread post prop says RH.. didnt Bruce Hart (Riley )have a link to a righty?
fanofccfan
Yes he did. Did not see it till late Friday. I will call him tomorro. That one I assume is out east as well.
peter1234
i am on the phone with the woburn guy he is going to call you if it was you that called from a 402 area code then he has your #
fanofccfan
peter
i spoke with jason about the 440. would you possibly be able to look at it? he said it does not have a conventional water pump but has two sherwoods???? do you or anyone know if that is acceptable for my application? freight is another issue i will have to check into. he also might know of a 72c trans to bolt on the back...he was going to call a buddy of his. thanks for the help. bill |
Fibersport
Groupie Joined: September-30-2008 Location: Lansing, IL Status: Offline Points: 76 |
Differences for a RH engine:
cam MAYBE distributor, I think Chryslers might have RH and LH distributors maybe circulation pump, some are bi-directional raw water pump might have to swap inlet and outlet hoses timing marks are on the other side of 0 degrees pistons might have to be turned around to prevent piston slap starter maybe alternator fan but alternator should be OK front engine seal - very important timing gears instead of timing chain firing order as stated above These are chevy changes, chrysler and fords might be different |
if your trying to source a 72c, go with a model number 10-18-002
