302 teardown |
Post Reply | Page <12345 7> |
I have the same basic setup Chris.I also have a 600 I'm rebuilding so I can try it out too. Since you already have the 450,why not just trying it? It's always easy to change. Mine was sure running fine last weekend,with JBear and Eddie in the back, it was moving right along
storm34
Well I got a DA106A Damper on its way from e-basicpower. Thanks again for the help Eric, I owe you a few! That and possibly a new carb were the only things left on my list worth mentioning. I may pick up a DUI and some control cables yet this week.
Any ideas on what carb I should be running with the 302 bored .30 over, gt-40P's, speedpro cam and a performer intake? I believe mine is a 450? Some of the guys I've talked to thought I may need to move up to a 600. Thoughts? |
storm34
Anyone have Eric's shop number? Need to call and order a dampener plate.
Motor should be back sometime this week or early next week. Then it shouldn't be too long before we hit the water! |
storm34
Well I've decided to use the stock crank on this one. If I could do it all over again, I would have gotten a seasoned one piece block and gone the stroker route.
Does anyone have suggestions on clearances when we put this thing back together? (Joe) |
horkn
That's precisely why I am a proponent of a 331 vs a 347. Piston speed is too high to be reliable on a 347, that and those ring lands are in bad spots on 347s. |
storm34
Joe, thanks for the heads up. Like Billy said, looks like I need to go on a search for a seasoned block with a 1 piece seal and order some more parts from Race City Marine
We haven't ordered a crank yet so if anyone has suggestions... I'll take them! I've heard an Eagle crank is the way to go but any numbers and corresponding parts would be helpful. Right now my only concern is that we've already magnifluxed my block, bored it out and it's sitting ready to be built. I'll have to talk to John and see if I can barter my old block with him? Unless someone here has a need for a freshly bored 302 block so I can get my money out of it? If I can work something out so I don't loose too much money I'll be full speed ahead with a stroker, if not I may have reconsider and wait till my next project to build a stroker? |
It was on my 67 where the shop got me a new block as the old one was shot. The didn't know that my crank would no longer fit.. Found that out. The hard way. Got a new crank and got her running but she nearly jumped out the boat.. Found out about the change in external balance weight from 28oz to 50oz the hardway as well.. That's why I left my number...get me a part number for the crank and take some pics of your flywheel and balancer (both sides) and let's
See if we can't make sure u find anything out too late. |
Yeah what Reid said and newer crank sometimes also means new flywheel and balencer...
reidp
Chris, Number 3, since I believe Joe indirectly confirmed what i was saying about the stroker cranks not having wick lines at all, being designed for later model blocks with one piece seals and the one piece seals are directional. You don't want a "wickless" crank with a "bi" seal, as you're likely to end up mopping your bilge. Those blocks should be somewhere in the dime a dozen price range. Maybe $.11, but not much more.
storm34
Thanks Joe! Just got confirmation that it is in fact a 2 piece block. I guess our options at this point are
1. get a crank with no wick lines and use a bidirectional seal 2. grind off the LH lines and redo with RH lines 3. new one piece block with Reid's seal When redoing the lines, how much clearance do you have before you start changing the size of the crank drastically? |
Reidp definitely be da man with the seals, I can confirm that if you have a later stroker crank for one piece seal blocks u will need a one piece seal block. Other wise u will go to tighten your last cap and find yourself with a rotating assembly that doesn't rotate. 315 567 1273 - Joe
storm34
Reid, I've got dibs on one of them! |
A Reidp sighting! Back from Daytona yet? I think youre right about the "new" (1-piece seal) cranks not having wick lines. I would imagine the ones for the 2-piece blocks would have them though, right? Summit makes you specify which style you want when shopping for a crank. I bet if you throw those seals in the for sale section here you might sell a few... there always seems to be a market for impossible to find parts. Just make sure you keep a few on hand, just in case! |
reidp
I didn't think those new stroker cranks came with any wick lines at all . But if Chris or anyone else with a one-piece 302 needs a RR rear seal, I've got them, as I believe we had 25 made in order to get a decent price break, and like Tim said they were for the 347 we had built. I'll probably be stuck with them for years to come.
On the 351w, the change in 1 vs. 2 piece seals came around 1982 or 1983. Im not sure about the 302- but I would assume you'll need to know what year block youre using before ordering the stroker crank.
Im confused by Billy's comments, my understanding is as follows: -The 2 piece (older) block will have wick lines in the CRANK. The seal itself is bi-directional (no wick lines). -The 1 piece (newer) block will have wick lines on the SEAL, so it is rotation specific. The latter 1-piece (reverse rotation) seal is the one that is difficult to find- but I think Reid had some made up for when he converted his 347 from LH to RH. The 2-piece seals are nothing special and readily available. It sounds like youre assuming that your 302 is of the older, 2-piece variety. I would have a chat with your machinist and see if its possible to add RH wick lines to the new crank. If not, then going with a newer block and and Reid's seal is certainly an option. The crank would not need any machining in this case. |
storm34
No real updates on the motor progress other than the heads coming in and getting ready to order pistons.
I've had several good talks with Reid and Billy in the last couple weeks. I can't thank these guys, and all the help from you guys here on the site, enough as I would be either lost, broke down or still ticking away with out you all. I have a question on rear main oil seals. Does my (1978) 302 have a 1 piece or 2 piece oil seal? After talking with Billy, he informed me that you cannot find them for a RR 302. He suggested going to a junk yard a buying an old seasoned 302 with a 1 piece seal. I'm not opposed to doing this but want to make sure it's necessary. We've already done the work to my block so it'd save me the 100 bucks for the seasoned block and the cost of having work done to the seasoned block. This is where I get in a little over my head, so any information on this from a 302 standpoint would be much appreciated. Thanks. |
Are you guy's looking for the blue like mine? It's Ford Blue 1941 to 1948.It's a very high quality paint,I painted it 20yrs ago,here's the link,they have other Ford colors too.The cast iron is brushed,it leaves no brush marks,the steel parts and the bellhousing is sprayed.
storm34
Pete, that was one of my concerns before. I think your right and the 331 will be plenty of boat for what were going to use it for.
Looks like we found the correct colors thanks to Critter. |
critter
Not sure that this wil help....
I found this .... Ford Colors http://www.fordification.com/bumpwiki/index.php?title=Ford_Engine_Colors Light blue - a.k.a. Old Ford Blue 1963 (some applications) - 1965 Duplicolor DE 1601 (Ford Blue) Corporate Ford Blue 1966-1968 Orig Ford PN: EP-2075-C Duplicolor DE 1621 (Old Ford Blue) PPG DAR 13358 Ford Blue 1969-1981 Duplicolor DE 1606 (Ford Dark Blue) TRW #630224 Eastwood's "Dark Ford Blue" |
1980 Ski Nautique
1966 Barracuda |
Chris,
Go for the 331. I drove Billy's a couple years ago at GL and trust me, it was enough engine to say the least!!! Also, I feel it has a higher level of reliability. |
storm34
Gary, thats a great idea. I would love to catch up with the Doc anyway!
Reid, I will hopefully know tomorrow if nobody chimes in until then. Going to stop at a few places and see what they have to say. They said they can match it at the machine shop but I'd like to know what it is so I can paint the trans the same color. I'll give ya a call tomorrow either way. Don't want to bother you tonight as I'm sure you are with the Mrs. Here's a quick shot of the clean bilge. I used a bucket of hot water, laundry detergent and a scrub brush to start. Once I got everything loosened up I went over everything with a damp rag (wiring and cables). I finished by removing all the extra water with a shop vac and drying with a towel. Looks a little better than before, huh? I'll get some better quality pictures up in the morning. |
reidp
That green looks great! So who has the info for the very dark blue to go with it. I'm trying to do the one in JMurph's orange Promo to take to the SJRR.
Chris why don't you give Billy a call,he has a 331 for a reason.I think it's something to do to with the length of the rod to stroke angle and the wrist pin being up into the ring lands on a 347.Car wise your not up into the higher rpm's for long but boat wise you can go for miles! |
Chris, not much else to say other than !
Send some of that warm weather out east, will ya? |
Keeganino
The paint I used is Plastikote "Hot Rod Green" Enamel 500 degree engine enamel. Marty got me the first can and I bought a second. Car quest has it or can get it, but I would assume anybody that sells plastikote could get it. It is warming up here too. In the mid to upper 60's all week. Sweeeet!
1973 Skier |
storm34
Well I am back from a week of work in Vegas and got to enjoy some beautiful weather here in Iowa working on the boats. I started by taking some detergent water and scrubbing the bilge since the motor and trans are out. What a difference some elbow grease makes! I'll have to snap some pictures when I get home tonight to show the results.
On the motor end, I should be seeing the heads today or tomorrow. I was hoping they would come in on Friday but I guess we can wait another couple days. Once these are in we'll order pistons and get a stroker kit picked out. I'm still torn between a 331 and 347 but I've done some reading and am leaning toward a 331, nothing final at this point. While I'm waiting to get the motor back I figured I would start getting the Trans and misc parts ready for paint. I need to find some high temp green like Keegan used to get the mainfolds back to the original green, As for the motor itself, I am probably going to go back to the Dark blue and keep it more original looking.
More images to come tonight. Happy Valentines day! |
right up to the high end
my comment was geared towards stroking that 302 to a 347, not throwing in the towel and going with a 351, it was more or less if your going to stroke, stroke it..I road in a couple 347 mustangs (cars) well worth the efforts....lottsa low end torque
That was a very good deal then. Are you still using them or have you "out grown" them ?
