Wine When Runnig On Trailer |
Davey Boy
Newbie Joined: January-27-2009 Location: Canada Status: Offline Points: 14 |
Posted: January-29-2009 at 4:41pm |
Hi
I live in calgary AB Canada, I have a 1993 Sport. When I run the engine on the trailer,(hooked up with water of corse) I get a whining noise. It almost sounds like its coming from the direct drive. Anybody have an idea on what it might be?????? |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21135 |
Check and see if your driveshaft is turning in neutral. If its creeping, it will make some noise since the cutlass bearing isnt lubricated.
Davey Boy
Is it hard on it if I let it run for a while???
79nautique
YES it is if you are running it in gear, now if it is out of gear there is no issues unless it's getting hot. |
backfoot100
You can run it all day as long as you're not putting it in gear and you don't want to rev it real high. I would guess that 2000RPM is about max. Depends how good your water pressure is. Once the engine demands exceed the water hose capabilities, the hose can collapse.
Eddie |
