What should i do? engine blues... |
MorganLarson
Newbie Joined: January-06-2009 Location: United States Status: Offline Points: 1 |
Posted: January-06-2009 at 4:35am |
I failed my first test at winter. There are two small cracks in the block of my Chrysler 318 on my 68' correct craft. I'm considering a re-build or a new engine. Any suggestions? What engine should i buy and from who?
thanks |
Morgan
Morgan,
Considering the age of your boat, I need to state my opinion to keep it original and do something with the 318. A rebuild is certainly a option if the engine shows signs of wear. Do you know the condition of the engine? On the least expensive side and depending on where the cracks are, I've seen some decent brazing still holding after many years of service! What did you forget to drain? Have you just found us or just new to posting? Ether way, welcome. How about some pictures and what model boat is it? |
eric lavine
Pete, we missed you, and I would like to remind you that December 21st, 2012 is coming quickly...you never can have enough time to prepare
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6149 |
Yeaaaaa a mopar:). You have lots of options with the mopar. 318 blocks are easy to find plentiful in supply and cheap. I baught a 360 block from a local machine shop for 30 bucks.
Any 318 block will work in your application between 1967 and 1989ish. Pete wont like me for this but you could swap for a 360 the only difference is the right side(from the front) motor mount is just a little further back than the 318. Sorry Pete:) haha. If you are looking for cheap power with the 318 go with flat top pistions and some 340 or 360 heads, 4BBL intake and it will be like a totally different boat. If your somewhat mechanically inclined assymbling the motor yourself will be fun and save you lots of $$$$$$$$. |
critter
Platinum Member Joined: January-11-2008 Location: New Hill, NC Status: Offline Points: 1227 |
Morgan,
Have to agree with Zach on the availability of the 318 blocks. If you search on ebay, you will find a bunch. Is yours a 318 Poly head ? I am currently putting my 318 Poly head back together and would like to agree with Pete that it should be kept close to original. Reid will even be able to help you with the correct color paint to order... as can I now.. You may want to tear it down to get a levelset on where your are as far a wear. You may be able to pick up another 318 block, and just use all the internals that you already have. Good luck, Roger |
1980 Ski Nautique
1966 Barracuda |
phatsat67
it could be a poly motor but the last year they were used in a passenger car was 66. The company that maranized the engine may have had a surpluss of poly motors. The good think about the original look of the engine is that unless you look at the casting numbers on a mopar you cant tell what it is from the outside.(that being on the la motors not the poly.) 360's have a slightly different vibration dampner due to being externally balanced.
62 wood
Zach, First off , Im not by any means a Mopar guru, but I think you might also have trouble putting the 318 marine oil pan back on the 360? Only reason I think this is, I bought a 68 Barracuda last spring. It was an original 318, but now has a transplanted 360. When looking at the boat, I noticed the marine oil pan had a horizontal weld-line all the way around it. I was told that the 318 and the 360 had different size mains?/and they had to graft the bottom of the 318(marine) pan to the top of the 360 pan. Does this sound right? BTW, It is an AWESOME setup....with a 12-16 wheel, it cruises around 2 to 22 hundred R's, and is good on fuel( until you kick the 4bbl in .... ) Plus it runs in the 50mph range.. |
phatsat67
Your right 62. The pan wont fit because the 360 has larger mains/caps than a 318. You could how ever with no modification at all transplant a 340. They are identical other than the crank and bore but a little more pricey because of their muscle car use.
Zach,
I have nothing against engine internal mods!!! I've mentioned it before that it's really the outside visuals that matter. The most common "upgrade" with classic boats is turning a 283 Chris marinization into a 350. There really isn't a ACBS judge around that will be able to tell unless he wants to get the wrench's out!! Good point on the difference between the 340 and 360. Steve, interesting oil pan modification! Guess they went the easy way without having any luck finding a 360 oil pan. I'm surprised because there are lots of 360 marines out there. |
O-Town Dave
Newbie Joined: October-18-2008 Location: United States Status: Offline Points: 37 |
But I have good news on a 360 swap! It is a pan adaptor... I sent this to Reid but will post it here on a mopar thread
http://cgi.ebay.com/ebaymotors/Mopar-318%2F340-to-360-oil-pan-spacer._W0QQitemZ270325645791QQcmdZViewItemQQimsxZ20090104?IMSfp=TL0901041110007r5849 http://stores.ebay.com/Liuzzo-Brothers-Racing The links are acting up for some reason.. |
O-Town Dave
The 360 might have a bigger rear main cap but the groove for the seal area is smaller than a 318's. For cheap money that spacer makes the 318 pan work on a 360!
phatsat67
You would also have to get the engine balanced with the flywheel and spring plate bolted on it because 360's are externally balanced or have the flywheel balanced to the motor. When I had my motor internally balanced it was around 50 extra dollars well spent because I can now run any type of neutral balance flywheel, flexplate, or torque converter.
The 318 or 340 will probably be the easier choice in this application if he isnt mechanically inclined. |
O-Town Dave
Or find a 360 flywheel. I almost sure that they are the same as the auto ones....
O-Town Dave
The weight to be removed totals 19.79 oz Keep in mind that this is for the pre magnum engine. if you wanted to use a newer 360 magnum the balance weight is different .
