#2 trailer work |
Post Reply | Page 123 14> |
storm34
Posted: September-09-2010 at 6:25pm |
Ok guys, I've got an appt to have some new springs made for my #2 trailer. I think i'm going to have a new axle put on while i'm at it. If I remember correctly the original was 2,000# or so. I was thinking of going up to 2,800# range. Both the axle and springs look to be pretty played out. Below is a picture of what it looks like right now with the Tique on it. I have the guides, but they will need some work as they are rusted at the bases.
Any suggestions of what size axle to put on it or any other info I should know before I take it in? |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21133 |
Chris, I looked into this when I went through my 2 #2's a few years ago. You will find that most axles/hubs will carry a rating around 2200, then it goes up to 3500, and then 5000. Hubs will follow these ratings, tires and springs not so much- but you need to consider them all.
Long story short, I decided to stay at the 2200 lb rating. This was the only weight rating I could get in a 4-lug hub, which I wanted to keep. It also ended up being about the max a 13" trailer tire will handle (1360 x 2 = 2720). I dont recall the ratings on my new springs (they were custom), but going a little beyond the other components wouldnt be the worst thing in the world. It appears you have 12" wheels/tires on that trailer, which probably have a pretty marginal rating for the boats you plan to carry... while they would probably get the job done, they will likely still be the weakest link, even if you stay with the 2200lb hardware. You would probably have to upgrade those to larger 5 lugs if you go to a beefier axle. I wouldnt hesitate to stay with the 2200lb stuff though- Ive towed my Skier trailer back and forth to GL twice without issue, so just keep an eye on bearings, tires, etc and you'll be fine. |
storm34
Tim, what would the 78 #2's have on them for wheels? 14?
I think I told you already, but this was under a late 60's mustang (you can tell by the fenders). I wouldn't mind making it look a little more like a 78 #2 but I've also got the 70 skier which fits the current look. That boat won't be done for a while so I figured I could do both by changing the fenders out? Edit. Are these the 14"? |
Chris, I would keep that 60's #2 exactly how it is. I would keep the fenders that are on there now- you can stuff 13" under them (just barely) if you want. Thats what I did with mine. Bruce's trailer has the other fenders that were commonly used in the late 60's and early 70's (wider/flatter), the wheels look like 13's to me.
Personally, I think the 70's boats look cool on an older trailer, while the 60's boats look a little out of place on the larger tired, square fendered versions. The square fenders are not cheap to fabricate, by the way- and you would need to extend the rails to support them- so more welding and $$ involved. If you want to see what the original 14's looked like on a 70's #2, check out the diary for my Tique. |
Chris,
I agree with Tim on keeping the spring rate close to the original. All a higher rating will do is make the trailer/boat ride rougher. The trailer that I use for my Dunphy originally had 3500 lb. springs on it. I actually ended up going with 2200 mono springs (one leaf) and the improvement was very noticeable. |
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
and I agree with Tim on keeping the original fenders. Personally, I don't like those square fenders either (No offense Tim to you Tique). The 78 looks great on there and obviously so will your skier. Here is a picture of the original wheels (and rubber on the guides).
NEDLUTZ
Groupie Joined: November-26-2007 Location: Seekonk Ma. Status: Offline Points: 69 |
try this place for fenders,axles. I got brakes and backing plates for a good price.
http://www.trailerpartsdepot.com/index.asp?url=IND |
Chris, I did mine a couple of years ago,the big problem being mine has 12" tires. Almost impossible to find but Eastern Marine has them.They are 6 ply rated,1045 lbs. They are Chinese tho and thats what worries me. I would like to get new hubs and 13" tires. I'm still using my original axle but had new springs custom made.They started out 4 leafs and after I had it all together, I took it back with the boat on and they recommended to add another leaf.
Your going to need hat bushings if it's like mine and Eastern has them here no one else has them or could get them that I could find. If you need any measurements or pic's let me know |
storm34
Gary, you have brought that boat a long way!
I'm pretty sure my trailer is exactly like yours. How many hat bushings do you think I will need? I'll go ahead and order them now since they're cheap and I have the time before I take it in. Thanks for all the input guys, you're all awesome! |
Thanks Chris. I owe that to Keith and his site,before that I just used it. My trailer used 12 bushings, 6 per side,2 in the front spring eyes and 4 in the rear shackle eyes.
storm34
Perfect, I will get an order in tomorrow morning. Any thing else I would need?
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
The wheels on my trailer are 12" and I forget the size, but they are the heaviest 12"s I've seen. They are 4 lug. They sell them everywhere, but only in the spoked wheels. I recently put new bearings and hubs on it and had no trouble finding replacements at NAPPA. I went with new hubs as the old ones had cracks that were apparent once their machine shop sand blasted them.
Northern Tool has a standard (not spoked) 12" rim that uses a 4.80 or 5.30 tire. These are the rims that I used on my TeeNee for the Atom.
Riley
Pete, Gary pointed me to a supplier that has them also, but for some reason when they get up to a certtain size, they are spoked. When we bought the Classic the seller put a new axle and tires on it. He got us regular rims at that time. I bought a spare for it last year and looked for hours for a regular rim and could only find spokes. It is a 5 lug, 13".
No one seems to notice, but the Mustang trailer has one of each. |
We ended up getting the Northern Tool wheels for our #2's as well. They were the only non-spoked wheels I could find, at least in 13". Not quite the same as the original steelies, but close. Bruce, if memory serves, they are the same as the ones under your Classic, but in 4-lug.
Gary, was I unclear above? Northern Tool has them too. Ive got 2 sets. |
Naw Tim I said the only place I HAVE found them Senior moment I guess,yea thats it.
Keeganino
Grand Poobah Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
Good thread! I am going to redo my #2 trailer this winter. Gotta get in these last months on the water before I tackle it though.
1973 Skier |
storm34
Ok guys, went to the only place in Des Moines that said they would make springs. He said at least $150 for each! Labor was going to be about 350 bucks + axle, hubs and bearings and putting it all together. I told him I was going to get wheels and tires.
Does this seem high? |
storm34
Just got off the phone with Woody. I introduced myself and said I was working on a Correct Craft #2...his response was "thats funny, I'm on Correct Craft Fan looking at a post about a #2!" How awesome of a resource is Correct Craft Fan?!
I called every freaking trailer place in Des Moines and they all said they can't get me the springs I need and they all referred me to the place that quoted me this morning! Wood has the right springs, I think he said for 80 bucks. Much cheaper than the 150+ labor I was quoted! |
Thats a good price I think Chris. I paid about 65 ea for mine then had them add a leaf later,so I bet it was about the same.That included new u bolts too.No shipping cause they were local.
davidg
Grand Poobah Joined: January-07-2008 Location: NW Chicagoland Status: Offline Points: 2239 |
Gary....where did you get your springs in this area? That is on my list of things to do this winter as well for my #3. When I load the boat on, the fenders come down very close to the tires. The springs are old, and the boat has gained a few pounds over the years. |
Spring Align in Palatine Dave,ask for Mark. Take him your old one and he can make them up. Have him make up new U bolts too and get those hat bushings from that place above.
storm34
I'd say the old springs are a little shot, huh?
Hopefully going to get the spring seats welded to the axle tomorrow. Should be back together pretty soon, can't wait to have a trustworthy trailer. |
Are those the springs from Woody then? What axle and where did you get it? I'm going to get new hubs soon and I really want to go to 13" wheels too so I can get some Goodyear tires. I just have a bad feeling about these 12" foreign tires,and I want to pull my boat a long way this comming March
SNobsessed
Gary - Don't assume the Goodyears are made in the USA - Some are & others, well . . .
I didn't know that Chris,thanks.At least they are willing to put Goodyear on them.I have Loadstars on there now with an 800 number on the sidewall for questions which makes me wonder
storm34
Gary, I'm a little torn on what axle to put on. I'm just happy to have some springs that aren't going to snap!
Woody sent me all the stuff to get the original back on quick. What does everyone think about putting a round axle and a little camber? |
Whats wrong with the axle you have Chris? I just cleaned mine up and reused.If I remember correctly the axle is a odd size,width wise also.Everything must have been custom made for Correct Craft.
