  New Posts New Posts RSS Feed - Help Noob Determine Interceptor Engine Size
vandykd3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vandykd3 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 9:24am
Originally posted by Tim D Tim D wrote:
Did you figure out which engine you have? The casting number will give you the year. Just because the boat is a 68 doesn't mean it has a 68 engine. A lot back then had blocks and heads from the year before. My 66 Mustang had a 65 block and 64 heads. How many bolts are on the bell housing? The casting numbers will end like C8 which is 68, C7 is 67 etc.
Tim D, I'm pretty sure we figured it out. Not necessarily the year perhaps, but the size which is what I needed to narrow down parts and part numbers and stuff.
Just clean the carburetor and install a rebuild kit. Put a picture here or some numbers from the carburetor.
Keno, here's some pics of the carburetor. There is a tough-to-read stamp on one side. It's a circle with the number 120 inside and maybe some small writing around the inner circumference of the circle. Hope that's enough!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 10:08am
The numbers on that tag that's on the float bowel screw is what you need,that's an original Autolite Ford carb. Had the same on my Holman Moody. Napa might have access to a kit
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 10:11am
Looks like an Autolite 2100 to me.
That tag screwed to the right front of the fuel bowl cover will have the info you need for parts, rebuild kit etc.
I think that was the original equipment marine carburetor on your engine back then although it probably didn't have all the features that a later marine carburetor does.
Rebuild parts or a kit are available and they're a very dependable carburetor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 10:13am
I almost said Gary S can tell you about this carburetor. You're just faster than I am this morning Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 10:46am
I've been working on my typing    It worked but I needed more power so I put on the 4bbl! A little nervous about the overflow but I never had any trouble with it. I did notice that with the Holley that it did start easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 12:32pm
Working on my typing too, more work needed obviously but between us we got him covered on the carburetor. At least we gave him the same info.
I've had them or a variation of them on quite a few land based Fords in the 60's, 70's and 80's..
The truck that moves white stuff around in the winter still runs good with a later Autolite 2150 on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vandykd3 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 9:30pm
You know guys, the dumb thing is I saw that tag (Obviously, it's sitting right there!) but the grease was so heavy on it I thought it was the patina of the metal and nothing was written on it anymore.   Hahaha. You're right of course, it's an autolite.
So, in addition to that master list of all the advice you two and everyone else gave me, I just need the info from that tag and NAPA should be able to sleuth down the correct rebuild kit? Out of curiosity, how hard is it to rebuild a carburetor? Is it even necessary? Can it simply be cleaned? I want this thing ready to rock so I'm willing to dive into whatever you tell me to as long as you believe I'm not getting in over my head.
Last question, when it needs a new battery, do I get a marine battery?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 9:57pm
Well Gary will probably beat me to an answer but starting with the battery question, just an automotive battery or a marine STARTING battery is fine. If you get a marine DEEP CYCLE battery you'll cause several people on here to have symptoms resembling a mild stroke so don't get one of those. Besides they're more expensive too
It's nice to have a carburetor kit on hand if you're tearing into it....just in case.
Take advantage of those neighbors you mentioned, they should have carburetor experience and you can learn from them. Not hard but some help sure won't hurt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 9:57pm
You need a starting battery does not need to be marine avoid any type of deep cycle. That carb is real simple would not hurt to open it up to see if there is any crud in it and to do that you need a bowel gasket. Might as well get a kit because the accelerator pump will most likely be dried out too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 9:58pm
Dang missed it by that much. I would like to add change your plug wires one at a time, your neighbors might not know the reverse rotation firing order.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 10:00pm
Wow Gary
We're in sync today, my reply was longer and I type just as slow as you so I must have started typing first
But again, we agree
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 10:01pm
I'm on my phone and have fat fingers
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 10:05pm
I don't even try it on the phone unless I really have no other choice
You're good
Post Options Post Options   Thanks (0) Thanks(0)   Quote vandykd3 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2017 at 10:48pm
You're good
You know, you could activate the microphone that's on your keyboard and simply speak your replies. Of course, be sure to proof read!
Anyway, I guess the only thing I need to do now is Facebook Live the whole process and you guys and comment in real time   [<:o)]    I'll be sure to spritz the hull with some Axe Body Spray when I'm done so all the pontoons go wild.
Seriously, though, it seems you've hooked me with all the info I need to head to NAPA. A special shout to Keno and Gary S and to everyone who's added some knowledge. I seriously couldn't have done it without you. Stay tuned for my next thread where I solicit advice and know-how about restoring it to a former ascetic glory!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 12:14am
Yea you never really told us what it actually is
Post Options Post Options   Thanks (0) Thanks(0)   Quote vandykd3 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 6:14pm
It's a 1968 Correct Craft that we got from my uncle (for free!). At some point, a fabricated steel tow cage was installed over the windshield area. I'll take a pic of it soon and post it. I love this boat. It sits so low in the water and sounds killer on the water!
By the way, is the carburetor indeed the 2100?
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 6:17pm
Oh no, oh no, I hope this isn't a 1st gen ski that someone put a tower on.! Oh gee,z that might kill me
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 6:42pm
David,
I sure agree with Steve and am even wondering if you should post a picture of a classic with a tower.
Steve,
In David's first pictures, you can see side pockets so it may be a Cuda or Stang?
Post Options Post Options   Thanks (0) Thanks(0)   Quote vandykd3 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 7:31pm
David,
Steve,
Well, since it wasn't me who (possibly) mutilated it, I can't take any blame so lay down your stones, check it out, and opine
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 7:31pm
Indeed it is an Autolite 2100
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 7:32pm
Oops double post, I was too distracted thinking about Pete and Skutsch simultaneously having "the big one" when they saw the pictures.
It your boat, do what you want with it and enjoy it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 7:47pm
I'm still alive!
David,
Ken is correct that it is your boat, you got it for free so lets get it running so you can enjoy it. The model is a Barracuda.
BTW, it's not as bad as the wood Atom that had a home made steel tower on it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 8:45pm
Pete is seeing red so bad he thinks a Mustang is a 'Cuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 8:48pm
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 9:12pm
That's a Doozy, lol.
Not sure if you have ever pulled a wakeboarder with your boat yet, if not be aware that if you have a big guy back there and he takes a hard pull from wide out that tiny hull is about going to end up on it's side and you will really need to drive that thing to keep it going where you were previously aimed.
Brave of you to post those pics though, great job!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote vandykd3 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 9:39pm
Guys, help a noob out. I'm not getting the Barracuda/Mustang jokes
Brave or naive, quinner I now see I'm in the purist's den
My 6'8" brother wakeboards behind it. We're skinny, though, so I haven't noticed any dangerous pulls yet. I'll be sure to have that possibility on my radar, though, thanks!
I realize this boats not in the best shape. Sooner rather than later, I'd like to reupholster the engine cover, put new carpet in and get some dash gauges working. As of right now, only the rpms works
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 9:59pm
How are the stringers? That would be my concern before you go after the cosmetics. Do you know when the last time an engine/prop shaft/strut alignment was done?
Post Options Post Options   Thanks (0) Thanks(0)   Quote vandykd3 Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 10:20pm
Crap, I just Googled what stringers are and I'm pretty nervous. After I finish tuning up the engine, I will do the research on exactly how I figure out the condition of the stringers. As far as the alignment goes, I'm sure it has not been done in a long time. I imagine that something I should probably take it to our local boat mechanic for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 10:36pm
Yours is a Mustang somewhat different from a Cuda
Here is a Cuda-
And a gratuitous picture of my Mustang-
Cuda is a bit longer and wider but the big tell tail sign is smooth hull under the gunnel. A Mustang like yours and mine has the molded in "flash" right under it's gunnel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2017 at 10:50pm
David,
Have you found the FAQ thread in the maintenance section yet? Lots of links to great threads on almost any subject. Check it out and if you don't find an answer, we're always around to help out. There's even a link to a fantastic thread by Tim Morfoot on how to check the stringers. There's even a video in it.
Regarding the alignment, it should be checked and most here do it themselves but, the condition of the stringers could influence alignment. If the stringers are bad, then they may not hold the engine position.
