does thermostat open? |
weitekampt
Senior Member Joined: July-08-2006 Location: Fisher, IL Status: Offline Points: 457 |
Posted: November-03-2006 at 9:55am |
Wondering if somebody could help me out. I was wondering if the thermostat actually opens if you only run the boat for 10 minutes on the trailer with the garden hose obviously. You are pumping 50 degree water into the motor at all times. I know on my truck we had to rev it up to 1700 rpm's just to get it warm enough to open the stat. Granted it is a diesel with 203 degree stat. So will the thermostat actually open if you run it on a hose? What is the max rpm's that you can safely run while on the hose. I bought one of those valve things from skidim for hooking up the garden hose to your water intake. Should be good flow.
I normally take the raw water pump hose that goes to the thermostat housing off and pour RV antifreeze down there to fill the motor and manifolds. I would think with the thermostat closed (never ran engine)that antifreeze would never reach the block, but when I open my handy dandy valves, pink antifreeze drains out the block. So I am a$$uming that antifreeze is getting to the critical areas of the block? I am going to hook up this new valve for the garden hose this weekend. I am going to let it run for 15 minutes or so and fog the intake properly along with pumping stabilized fuel into the carb. Again, this is where the question arises....will running the boat 15 minutes be good enough for opening the stat? I am going to try this bucket and antifreeze thing and see if it will suck it into the motor. That is probably the best way, but I am very concerned about the block and if antifreeze will get to all the critical places. Thanks in advance for any help you guys may have! Todd |
M3Fan
I believe there is a bypa$$ hole just forward of the T-stat which lets a small amount of water through to the block no matter what. This is probably the only way the block initially fills with water once it's drained. I'm not speaking with conviction for a while now after that hitch thing on PN.com.
David F
Yes, the thermostat will open. If not, the engine would over heat regardless of the water or air temp. Boats do NOT have fans that could keep an engine cool enough in very cold air temps and idle like car or trucks do.
Once your temp gauge comes up to normal operating temp and stabilizes, your thermostate will be open. Just give it few minutes after it comes up to temp with the engine running. |
M3Fan
Here's the hole I'm talking about, just north of the T-stat hole.
It was proposed on the MC site that in most FWC motors, the thermostat opens to allow water OUT of the block, rather than INTO the block. This diagram was referenced:
If this is the case, then A/F would reach the block when it is poured in, regardless of whether or not the boat is up to temp (thermostat open or closed). Fact or fiction? |
wrong, it will feed the exhaust manifolds constantly and very little if any at all will go into the block.
Drain the block remove the t-stat housing and t-stat pour in the antifreeze and be done with it. This crap about sucking it up and doing this and that is a big waiste of time, waistes more antifreeze, takes longer and doesn't do as good a job. Your a$$uming that the block has 100% antifreeze in it when you see it come out of the exhaust at the transom and in fact it's not it's deluted antifreeze and you'll use twice as much as needed. Bullsh*t way of doing things and I can careless what all you other's think that do it that way and have for years. do it that way and leave it outside up north and you'll be buying a new block come spring time. |
M3Fan
TR- I'm thinking convection would cause hot water to rise up through the T-stat, so that might make sense. Cold water naturally would go into the inlet hole that I described before, but if there is no hot water to displace (T stat closed) then it wouldn't go down the hole.
Edit- Think about this for a sec- if you drain the block completely, then put all the plugs back in and hit the lake, I'd highly doubt that the engine just runs with no water until the T-stat opens to let in R/W- The T-stat needs water to Xfer the heat to it in order to operate. I'd guess water fills the block the moment you hit the key with a completely drained, cold engine. |
water is constantly circulating in the block if the engine is running t-stat open or closed, when the t-stat opens then the path of least resistence allows it to flow throught to the exhaust manifolds and out while the cold water goes into the circulation pump and through the block and not the exhaust manifolds that's why the extra hole is in the lower t-stat housing. when the t-stat is closed there is more resistance in that hole than there is in the top half of the t-stat housing thus the flow goes to exhaust manifolds because there is no pressure there, thus the path of least resistance. when the t-stat opens it creates more pressure in the upper half of the housing and there is lower pressure at the little hole in the lower housing caused by water leaving the block and out the exhaust now the path of least resistance is in the little hole which is now seeing a vaccum created by the circulation pump.
M3Fan
Right- the question here is, if the following conditions are present: 1. Engine is cold 2. Block is DRAINED Does the T-stat have to open to allow water into the EMPTY, COLD engine. I say no. I believe the block will fill in this case the moment you start the boat. |
you changed the conditions no one said anything about draining the block first, if you do then you better fill it back up before you start the motor or your going to create a big air pocket in the block and have very little antifreeze/fluid if any at all will be present in the block and it all will be pumped out the exhaust leaving the block without any coolant.
M3Fan
I may have changed the conditions, but mainly just to dispell the common thought that the T-stat is the only way water gets into the engine. I think we're all on the same page with this now. I've started boats on the water with drained engines for a long time with no issues. They fill right up! |
I would *think* the hot metal block will transfer enough heat to the T-stat to open it up.
well no it wouldn't, the piece that actually opens it is isolated some what and by the time it opened up the block would be over heated already then you dump cold water into then the block cracks instantly. |
David F
PCM makes no reference to the thermostat having to be open when filling the block with antifreeze. PCM simply states to elevate the RWP output hose higher than the thermostate and pour in the antifreeze. This is precisely what I do each year and never have had a problem with the block filling with antifreeze. So, I suppose it is possible that the circulation pump pumps against the the thermostate AFTER pa$$ing through the block.
However, in the process of fogging the engine and getting the fuel stabilizer to the injectors, the engine is always warm when I pour in the antifreeze. Whether the thermostate has time to close or if the cool antifreeze would abruptly close the thermostate, I have no idea. What I do know is that the engine accepts the antifreeze and I am not loosing it out the exhaust manifolds as I leave the exhaust manifold plugs out and would surely see antifreeze pouring into the bilge if this was the case. With all that said, I am going to agree with Chris and say that using the RWP and sucking in the antifreeze seems like a big ha$$le, waste of antifreeze, and totally off handed way of achieving an otherwise simple task. But, I do not know if such a method would be detrimental or not...depends on how well it is done. |
M3Fan
Which is why the block fills up on its own with the T-stat closed through that inlet hole when started cold and empty. |
I agree with your (and DavidF's) winterization technique, Chris- I do the same. The question is if the block is drained and refilled when it is cold, is it full of antifreeze, or did you simply fill the manifolds instead? For those who use toxic (regular green) antifreeze, what is the proper procedure come spring? I know that the A/F is drained before starting the motor- should the motor be filled back up with water? If not, then the motor would be running dry until it gets up to temp- a$$uming the thermostat opens to allow water into the block |
M3Fan
YES, the block fills when empty, not just the manifolds, whether it is warmed up or not, whether the Tstat is open or closed, the damn thing FILLS UP. It does not run dry until the T-stat opens. |
the only issue you can have is that you can create an air pocket in the block if the t-stat is closed.
If the engine is cold, you drain the block, remove the hose from the topside of the RWP it will fill the block but it also can create a air pocket as well. that's why I like to remove the t-stat and pour it in there, I've even gone as far as running the motor with the upper t-stat housing and t-stat removed to circulate it to remove and mix the green car anti-freeze, the RV/Boat stuff I don't |
David F
You know, this forum gets very slow once everyone puts their boat away for the winter. It is kind of fun to have this the banter going on...
Keep it up! What ever method you chose to winterize the engine, just make sure it works and don't let that block crack. Someone should come up with a temperature controled electrical outlet that switches on once the temperature falls to a set point. then, you could put an incadesant light bulb under the engine cover and when the temp falls below a certain level, the light switches on and keeps everything from freezing without having to remember to turn on the light. Just a bit of added insurance if your winterizing techniques where not perfect. |
Well that answers my question. Like DavidF, my engine is usually warm when I pour in the antifreeze. Glad to know I could drink another beer before backfilling and not worry about filling just the manifolds. |
wrong the block will parcially fill up and create an air pocket in the heads and intake and then start to pump it out to the exhaust manifolds, agian water flows the path of least resistance, so once you create the air pocket in the block there is less resistance for the water to flow out to the exhaust manifolds than there is for it to continue to fill the block, so for the block to completely fill the t-stat has to open and let out the trapped air. |
if your getting the engine hot draining it then pouring cold fluid back into it that's real stupid and your just asking for problems and a cracked block. |
David F
My thought is that t-stat does not make such a perfect seal that air would not leak past it. Even so, if a bit of air was trapped in the heads during winterizing, then this is less of a freezing/cracking concern and more of a scale build-up concern.
David F
Chris:
There is no way that pouring in cool (not ice cold) antifreeze into a warm marine engine is going to crack anything. The operating temperature of 160 degrees or so is very low and not high enough to be concerned about thermal shock when adding antifreeze slowly via the RWP hose. |
M3Fan
First of all, I've really got to cut down on visiting this forum. If I didn't run IT here, I'd probably be in trouble . A good example, TR, would be when we test drove your boat. I drained the block completely several weeks before because it got really cold a few nights. I put the plugs back in the morning of the test drive, never starting it for those 2 weeks. When your dad drained the block in the driveway, it was full. |
weitekampt
Hey guys, thanks for all the input...I think. Yes, the engine is stone cold and the block, manifolds, and j-pipe were all drained. Cold and empty system. Never started the engine, just poured antifreeze in the RWP hose into thermostat housing.
It sounds like the system is filled with antifreeze. I am still going to run the engine tomorrow (after collecting the antifreeze from the valves...liquid gold!) for fogging reasons. If I have a thermostat gasket in the basement I am going to pull the stat and fill it that way. I know it is a pain in the a$$ and probably a waste of time, but oh well. I have done it both ways and never had a problem. But if I have a gasket, that is what I will do. I was listening to the weather and next saturday is supposed to be 60 degrees. Heck, I may REWINTERIZE next weekend. Need to break out the drysuit. Thanks for the input guys. I never thought about the air pocket thing but now aware. Stay warm! |
M3Fan
The air pocket theory may be more relevant in a pressurized cooling system like a car's, not in a RW cooling system.
bkhallpass
I don't usually jump in on engine topics, but this is one I know something about. I've probably drained and filled in excess of 10,000 engines (put myself through the first 5 years of college working in a radiator shop). I can say from experience that all engines will get an air pocket if you fill them with a closed thermostat in place. This is why you "burp" a cooling system, and then top off the coolant level. I have my doubts that the air pocket would make much difference in terms of winterizing a boat, but then again, I don't live in a cold climate. BKH |
Livin' the Dream
Tim D
The T-stat is where water comes out of the engine, not "enters in the engine".
Tim D
yes that's right, that's why it can and will trap air in the top of the motor unless it is open. |
