351 or 302 |
fuelctrl
Newbie Joined: June-01-2006 Location: United States Status: Offline Points: 33 |
Posted: July-04-2006 at 11:05pm |
there is no tag for the engine and I am having problems wether my motor is a 302 or 351. does anybody have an idea where else I could tell which one it is. please help
Tim D
Grand Poobah Joined: August-23-2004 Location: United States Status: Offline Points: 2637 |
The casting numbers on the block and heads should tell you.
Tim D
the intakes are different as well.
AWhite70
Senior Member Joined: March-05-2004 Location: United States Status: Offline Points: 242 |
The intake Manifold on a 351W is a lot wider than a 302. If you measure the width of yours someone here should be able to compare it to theirs.
Someone good with engines should be able to tell by looking. You could post a picture here, but it might be somewhat difficult to tell without seeing in person. |
stang72
The 351 is about 11 inches across from the inner edges of the valve covers (where the heads meet the block)...302 is about 9 inches across.
dans
Senior Member Joined: March-23-2006 Location: United States Status: Offline Points: 187 |
Look on skidim.com The have pictures of a lot of motors on the main page.
measure the intake
dchris17
Gold Member Joined: May-28-2005 Location: Weatherford, TX Status: Offline Points: 573 |
Depending on the year, the 351 also has an oil cooler that the 302 does not have.
