86 SN rebuild |
Post Reply | Page <1 91011 |
Ranger
Senior Member Joined: August-23-2010 Location: San Diego Status: Offline Points: 151 |
Balloons? What a great idea!
Thanks, Jeff |
lakedog55
Hi,
I am working on a 86 as well and have enjoyed your thread, On the drains. Do you guys think it needs the fiberglass or will a good coat of epoxy do the same thing? Just wondering . I put in drains for under the floor and they are epoxy coated and am planning to use 5200 and pvc with a screw cap so I can drain if ever needed or check for water. |
Lakedog55
I would glass the cut outs. The glass is the strength and the epoxy is the adhesive. Straigh epoxy resin is brittle and can crack. You don't want any spot to be a potential for water to enter the stringers.
Jeff,
I did my drain's exactly like Tim showed in his diagram. I did do it before I installed the stringer, but I put the holes where CC put them. After I installed them I noticed they weren't in the best place(lowest point) So I filled them and re-drilled new one's. So I ended up doing them in place after all. (PITA but done) PS the more cuts the easier it is to get them to lay flat. |
Ranger
Thanks Gun Driver, I appreciate the advice.
Jeff |
Ranger
Since it drives me nuts to be on the second page, I'll give everyone a quick update. All four stringers have the 2/2, 4/4, 8/8 and 1st layer of biax. I'm happy with how everything is looking so far. Hopefully we can get all of the ribs, drain holes and blocking done this weekend. Once that get's completed, we will get working on the battery box area.
Jeff |
Ranger
Haven't been here in a while, but it looks like we are back at it. Had a life changing event that took a while to get through..... Anyway, things are good.
Update: Just had three good days working on the boat again. Have all 4 stringers pretty much finished. Completed the top wraps with biax today. Our next step is to clean up the entire hull, stringers and sides with a grinder and lay a few more small pieces of glass in some of the corners. I'll try to post some pictures later. Jeff |
Ranger
Here are a couple of pictures of where we are at with the restore.
Jeff |
Welcome back!
Ranger
we are still plugging along. I have decided that I hate grinding and I hate itching. I think they go together.
Anyway, we have the stringers pretty much done, except the corners and curved areas need a little more attention. I did drop it back on the trailer yesterday, which seems like a huge accomplishment. Nice to see it back where it belongs. I even moved it into the barn, so I don't have to deal with the coming weather. I'll start to tackle the battery box area within the next week or two. Jeff |
ski-guy
Groupie Joined: September-12-2011 Location: West Kelowna Status: Offline Points: 62 |
Has anyone tried putting an additional battery box in the airbox (other than way under there (PITA?)should be plenty of room and it will be up much higher to allow it to drain)?
1980 SN - don't worry dear, I may have $10+K into this project boat but I can easily sell it for $5k
2000/2001 Glen-L 'Squirt' 2006 Malibu LSV |
