prop will not spin |
Guests
Guest |
Posted: February-20-2006 at 11:32am |
i have a 1994 sn, and i try to turn the prop or the drive shaft by hand and can't. is this a big concern? seen similar post, but none where it wont spin at all..it is cold outside around 55-60 f..
bwooton
Groupie Joined: June-13-2005 Location: United States Status: Offline Points: 91 |
Make sure the boat is not in gear. Not to be a smart A## but i have done it with cars.
Thanks Bobby
there's no replacement for displacement |
82tique
Senior Member Joined: June-04-2004 Location: United States Status: Offline Points: 339 |
colder temps will make it harder to spin
Life is Good.
Loosten the coupling bolts, and if it can then spin, the engine alignment is WAAAY off.
Guests
Guest |
if the bolts are loose, it should spin? if it does then it needs aligned/...seems like if it doesnt spin with the bolts loose then its outta whack?
Ryan you need to remove the bolts and seperate the coupling halfs then try and spin it. 50-60 degree weather won't keep it from spinning. Before you unbolt things try disconnecting the shift cable at the tranny and make sure the shift arm on the tranny is over the N or in the middle, neutral, then try and spin it, try moving the arm a little one way or the other to find neutral, this will be much easier and quicker than unbolting the coupling. If it still won't spin then unbolt it and if it spins then you'll have to figure out what's in a bind in the tranny/engine.
David F
It could be that the shaft has just stuck to the cutlass bearing from being layed up for awhile now.
Get a couple of broom handles or similiar and try to break it free. If it stills turns exceptionally hard, then check out the transmission. |
