My new 2001 and my first! |
Post Reply | Page <1234 23> |
critter
This motor came from Fl so it has not been below freezing this year. How long has it been out the boat ?
Get as much water out as you can find and keeping it in the garage with doors closed should be ok for now. Might want to put a bit of anti-freeze in it for the rest of the winter. |
1980 Ski Nautique
1966 Barracuda |
storm34
Thats the boat I was talking about! I think I read that it was re-done by a guy who worked at correct craft for many years. I also saw pictures of it weighted down for surfing. It was so severely weighted it looked like the gas overfill was submerged. As I remember, it was a pretty controversial picture at the time.
Hollywood, I saw those exhaust hoses too! Would that be a safety issue? |
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
This one I'm going to guess at seven ballast bags in that pic. |
MaddMarxx
Heres another cool 82-83
storm34
Thats the one!
Is that a moomba decal on the back of that boat? Looks pretty close! |
akabulla
Gold Member Joined: November-15-2008 Location: United States Status: Offline Points: 649 |
I could only find one drain plug on the right side of the engine. This one:
Do I have to take out this sensor to drain the other side? There is no plug but this is in the same place as the plug on the other side? |
critter
That is correct. Remove that sensor for draining that side of the block. I did not see that sensor earlier. duhhhh.
Try to catch that water to and let sit if it looks like it has oil in it. |
1980 Ski Nautique
1966 Barracuda |
Akabulla - If your looking to see if the water is oily, put some salt in it, shake it up good, then let it set. The oil will separate out.
akabulla
I took it out and I am going to let the water sit overnight. The PO emailed me back and said that the engine was taken out of the other boat a few years back and he thinks it is just sediment in the water. We will find out tomorrow but it doesn't smell like oil and my hands cleaned off WAY to easy
Black disgusting water is actually the norm out of cast iron after sitting for a while, oil on the other hand is usually distinctive. So dark is not an issue, if its got real oil and its ever run before for a any amount of time thats an issue.
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
Hollywood, I've seen that boat quite a few times & i have never noticed those exhaust hoses until you pointed it out. Wow! all that time into a custom 'resto' & decided to skip that part?
That's sweet you've gotten the hull & all those parts, should be able to make a pretty sweet combination 80's 2001 with modern touches. But just a hint... don't ever weigh your boat down like that guy in the picture... I remember seeing that a couple years back & he got flamed pretty hardcore...not smart. Best of Luck, Nate |
over here in the Brunstuck we would stick those pipes straight up and put som ran clappers on em
Kristof
Yeah Eric, and I'll bet they're chromed too LOL
Nice and shiny |
kapla
More than a ski nautique I would call that boat under that load an U-nautique!!!
sorry for the lame joke but it had to be said ahahaha |
Unique Nautique?
kapla
"underwater-nautique" as german U boat designation U-1 etc.....
Kristof
You guys ever seen the movie "Das Boot"... If you'd seen it Eric, you would know a U-Boot...
Das Boot The correct term for U-Boot is "Unterwasser-Boot" in German |
kapla
Thats right Kristof!!! excelent movie...
kapla
i think they are more familiar with the U-571 hollywood movie!!!
akabulla
You guys are a trip!
My windshield purchase from Florida fell through. Does anyone know about a one piece shield for sale? |
akabulla
Well I got all the parts out of the boat and sorted them all out. Not sure what I am going to do with 6 lift points but I am sure I can figure something out.
Ok, Here is my first question of my rebuild. The guy gave me the engine cradle for both the original 351 and the one that the PCM 330 was mounted in. The PCM 330 cradle as you can see in the picture is much wider than the old cradle. Question is: Should I use the original or should I make the new stringers wider and use the newer one? Seems to me the stringers would be to wide to fit the new cradle and might hurt the structural integrity of the 2001 Hull. It is almost as wide as the secondary stringers. |
Chopper
The 330 cradle looks exactly like the cradle in my 89 2001, and the 90 onwards 196's
I have asked the question to my comments below before, but not having had replace the floor in the 89 yet I cannot answer. The 89 stringers are wider spaced than the 82-88 2001's with the same hull. I would investigate how the 89's stringer system's are constructed and possibly recreate.? They may or may not have a secondary stringer system. I know the 90's 196's do, bot they are a wider boat. Only issue you will have is the lack of templates to use as your guide. |
akabulla
I think I could probably figure out a template to make it work. I don't have a clue what I am doing anyways so whats the worst that could happen
That's what I have you guys for If I make the stringers wider, I think my concern would be the height of the main stringers. The height of the secondary stringers towards the ski pole connection are not that tall so it seems if I make the main stringers wider they might not have enough height to include the needed strength for the hull. I posted something at the2001.com to see if anyone had a picture of the stringers in an 89. I couldn't find a pic of someone rebuilding their stringers of an 89 here but if anyone has the dimensions or the width then I could start to determine if I could go wider. Thanks! |
Aka - Can you get the 33's motor mounts to squeeze into your old cradle? Look for how much L-R adjustment you would have. I think this is why they coined to term 'shoehorn' for engine swaps.
Aka, there was someone who rebuilt an '89 on here- though I dont think they shared any pictures. Check my partial stringer thread and see what their username is.
If youre going to use the newer motorbox, I would lean towards using the wider stringer set up, as you know it will be wide enough to cover the cradle. The advantage of the newer cradle is the the mounts arent lag bolted to the tops of the stringers- theyre through bolted to the angle brackets on the cradle. Not sure how you would go about lining up the exhaust holes, though- 89+ ran the exhaust between the main stringers instead of outside of them. Another concern is the shaft log angle- the newer boats (97+) use a shallower angle than the older ones. Make sure you adjust your stringer height as necessary to accomodate this. |
akabulla
It seems there would still need to be some sort of structure under the mounts of the new cradle. Looking at the picture below there are bolts that go through the top but there are also holes for bolts to go in side of the engine mounts. Wouldn't the mounts try to lean inward if it didn't have support on the sides like it does on this temporary stand?
Nope- thats the factory set up, at least from '90 forward. Notice there are only vertical bolts on my tranny mount in this pic: |
critter
That is kind of hard to see so I put arrows on it...
No bolt in the bottom hole by the lower arrow. |
1980 Ski Nautique
1966 Barracuda |
AKA - The twisting force you described is minimized because the downward forces are the same on both sides of the engine. My '89 has the newer cradle.
I dont know about that. The torque of the motor is equal on both sides, but opposite. If youre just talking about the weight of the motor, then youre correct. Long story short, either cradle is more than strong enough to withstand both the weight and torque of these motors (probably by a multiple of 2 and then some). Either *might* work, though I would imagine the Excal mounts are a sure bet to line up to the Excal cradle. |
