'99 Pro Boss, belt on its way out ? |
Posted: July-23-2012 at 10:42pm |
Before you get a new sheave for the alternator, get some measurements. Use a set of dial calipers to measure the belt width in random spots and to measure the width of the sheave. It may not be high low spots (different widths) but rather a width issue.
wetneck
Groupie Joined: December-17-2011 Location: FLA Status: Offline Points: 66 |
just ran it on the hose, watched as the belt rode up and down on the alt pulley, looks like hi/low spots
also found the culprit of a ( sound) change last sat, plug wire came loose (( |
Check your sheave alignment with a straight edge.
wetneck
please look @ this photo and give your pro opinions if this is belt dust with a belt on its way out ??
feels powdery on alum angle in front and is most prevalent towards front/pass side and there are no other visible leaks of any kind |
