Removal of Swim Platform Brackets |
Author | ||
James T Brockma
Senior Member Joined: November-02-2007 Location: Indian Wells CA Status: Offline Points: 120 |
Posted: October-28-2008 at 3:09pm |
I am restoring a '98 SN 176. I would like to remove the swim platform brackets from the transom so I can repaint them and more easily polish the hull using a random orbital buffer. Does anyone know if the brackets are thru bolted (if so, how do I get to the nuts) or lag bolted to the transom. Also, any suggestions for the type of black paint to use to respray the brackets. The boat is not left in the water but I don't want to go through the trouble and then have the paint peel off.
Thanks |
Jim '06 216
'98 SN 176 |
SNobsessed
I don't know about the through bolts (someone else will for sure) but as far as paint you might want to look into black anodizing. Paint will probably peel off again.
BTW, my bkts aren't painted at all & have an oxided surface, but not very visible with the boat in the water - out of sight out of mind! |
woodyelc
Senior Member Joined: February-17-2004 Location: orlando Status: Offline Points: 376 |
They were put in with lag bolts. Just remove them to remove the bracket. make sure you recaulk the hole when you put them back on.
woodyelc
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21130 |
You sure, Woody? On my '90, the bottom bolts are lags, the top bolts are backed with nuts and washers. Im not sure you could get to them without pulling the gas tank, though. I had the half of the brackets that attach to the platform powdercoated, and they still look great 2 seasons later. |
The Godfather
Platinum Member Joined: August-13-2008 Location: Orlando Fla Status: Offline Points: 1766 |
To remove the brackets, the top bolts are thru bolted and the bottom are lag.
On the inside of the transom you might have to peel back the carpet to get to the nut's. I think the nut's are 9/16 or 3/4. And make sure you re-seal correctly. |
Jetski180
Groupie Joined: June-09-2008 Location: United States Status: Offline Points: 60 |
I would get the brackets powdercoated as well like TRBenj said. Powdercoating looks great and holds up better than paint.
79nautique
hard anodizing will last much longer than powder coating ever will and looks ten times better too. |
IF the brackets are aluminum, then I'll go along with Chris and a black anodizing. With the powder coat, all it takes is one pin hole for water moisture to get in and it's white rust time for the aluminum! |
Jetski180
Didn't know about hard anodizing. I looked at it some and would agree with you that it will last alot longer. Always learning something new on this great website. Thanks all.
79nautique
the powder coat can also be chipped much harder to damage anodizing.
you need to use type III, class 2 anodizing, Type II, class 2 is typical anodizing and can scratch pretty easy. Now as Pete pointed out if it is steel then powder coating is your best option. |
SNobsessed
They wouldn't use carbon steel for platform brackets, would they? I doubt if they are stainless steel - if so they wouldn't have painted them in the 1st place.
