foam flotation |
kiddo
Newbie Joined: January-07-2008 Location: United States Status: Offline Points: 1 |
Posted: January-07-2008 at 11:15pm |
I own a 1983 fish nautique. I believe that the foam is soaked judging by the way the boat sits nose heavy in the water.Would it be possible to eliminate the foam after the floor is replaced? Access hatches would be installed in two areas to monitor what goes on down there. What do you think?
help me if you can
87BFN owner
Foam replacement is much like oil selection on this site. There are lots of opinions as to whether or not the foam should be put back. There are good agurements on both sides of the fence. There are members here that have boats that do not have foam in them, so to answer your question yes you can leave the foam out.
Tomski
Senior Member Joined: October-19-2006 Location: United Kingdom Status: Offline Points: 227 |
I've got the floor out in mine at the moment and found wet but not soaked foam and wet but not rotten stringers (pheewwwee). The glass had just gone where the foam had collaplsed underneath and the bits of ply were shot.
I was thinking about the foam and decided I would replace it. I also thought about the insurance situation; foam is a safety feature. The boat is meant to remain afloat even if swamped, so if you remove it and it sinks will you be covered? Losing the baot would be bad enough but if you unlucky enough to sink in a channel getting stung with the cost of salvage as well would be a bitter pill to swallow. I guess the same question arises with regard to ballast; if you load the boat up with lead have you made it unsafe? Anyone any experience? |
Easily Parted From Money
BuffaloBFN
My first thought was- will the fish be going offshore? Tomski, you should have a capacity tag near your shifter.
Tomski
Buffalo,
The tag is long gone I'm afraid, capacity isn't really an issue for me as I don't ballast the boat anyway - I fend people better than lead, they're easy to move and they pay for gas! I was just curious what people's views were on the no foam/insurance thing. I made the decision to put it back because a boat we had a few years ago split an exhaust pipe whilst we were having lunch and sank to the gunwales, but we got back to ramp and on the trailer and had it running agian next day, so keeping afloat is a bonus. |
hasbeenskier
Wise.
hasbeenskier
BuffaloBFN
Pete had a little to say about insurance in another post, though I think the topic was about marine engine parts vs. automotive. His point(I think) was that if an insurance inspector caught an inconsistancy with the boat that related to the claim, the claim would probably be denied. Auto carb=Boom=no money! The DNR asked me where the capacity tag was on my old boat a few years ago. I reached in the glove compartment and handed it to him...he wans't happy. LOL You may have different rules accross the pond, but this guy checked me again later that year to make sure I had put it back. On the foam, mine will be going back in for insurance reasons and because I'm sure my big block would make a very efficient anchor. Speaking of ponds, don't you guys have some really deep lochs with nasties living in them? Heck, Nessie might not give your boat back?!!? |
eric lavine
the coast guard also requires life preservers too.. a boat is replaceable, if you tell the adjuster, well yeah i took out the foam that is required of course a red flag will go up...they are on a need to know basis...most of the times replacement values are less expensive than the repair costs of a soggy boat. the foam has nothing to do with saving the boat its required and its there to save your ass, seeing most guys that ski cant swim, when the boat sinks it gives you something to hold onto because you forgot your life vests
Mojo
Grand Poobah Joined: December-06-2006 Location: United States Status: Offline Points: 3104 |
Great point Eric.....!!!
05' SV211 TE
eric lavine
with all the discussuions on foam, ive decided finally that if i was to do my own boat i would not include it in the floors, because of the damage it causes. to rationalize why is these boats are designed for river and lake use, its there for safety and safety only, it is required for safety which i fully condone, it does not have anything to do with noise or stability because the hulls are designed for ridgity. if you were to use this as a long range fishing boat by all means the foam should be there who wouldnt want it 20 miles out. it is required as are airbags are on a car when manufactured and the choice is yours as to if you want to use foam or not. as with doing someone elses floors i would recommend putting the foam back in for liability reasons. I'll probably regret posting this but its my opinion as to what i would do with my own boat because ive seen alot of posts wondering why its there and if you should re-foam or not, its an opinion and i hope its taken that way.
Eric, Extra foam high and dry under the decks and gunnels is all it takes for safety reasons. About 60 lbs of flotation for every cu. ft. of foam. If swamped, the hull may sit quite low in the water but it won't sink.
87BFN owner
Don't forget your noodles.
Brktracer
Senior Member Joined: December-20-2007 Location: South Carolina Status: Offline Points: 387 |
How much foam is in these boats? Where is it located? Is the entire area between the floor and hull full of foam? Does anyone have a picture with the floor removed?
Thanks, Matt |
Hollywood
A LOT of members have posted pictures of their foamed floor, start searching. There is also foam sprayed underneath deck along the gunnels and in the bow.Look at skibum's photobucket page.
SNobsessed
I am thinking of leaving the foam out of the floor & putting it up under the bow & gunnels instead. I didn't see any connection to this in Skibum's photobucket but may have jsut missed it. If it's there, what pict # is it?
What kind of foam should I use & how to attach - adhesive? Thanks, getting itchy to start cutting that floor (bad pun) as soon as the weather thaws. Chris |
SNobsessed
Thanks much - something else to research this cold weekend!
SNobsessed
Guys - Another question - should I be digging the foam from around & underneath the battery box? I reviewed photos of that area & it looks very tight with the air ducts right up against it. I thought about pulling the battery box out but have a way of cracking things when I pry on them.
I saw on TRBenj's project that he left the BB in, so I am wondering if it's a nesessary step - my floor has no soft spots that I can find. Chris |
eric lavine
if you dont you will always wonder...
78 Southwind
Newbie Joined: November-01-2007 Location: United States Status: Offline Points: 6 |
I am also going to re-foam my boat. Did you find out where to get it foam and what type? Thanks
SNobsessed
Compliments of Pete:
handi-foam |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21136 |
US Composites. I believe I used the 8lb density, but I think CC used the 2lb stuff. |
eric lavine
Fiberglass Coatings Inc. 3 locations in Fla.
1-800-272-7890 great customer service, I would price shop, but good customer service is a plus |
Bob's2001
Senior Member Joined: March-28-2005 Location: Lake Jackson TX Status: Offline Points: 241 |
What's the best way to mix the 2 part foam, by hand with stick or with a stirrer in a drill motor? I've searched but there are so many references to foam my brain is starting to foam...maybee I need a foamy beverage.
Bob Ed
83 2001 |
eric lavine
there is no time with a drill, use a stick, mix a test sample to get a feel for the product
eric lavine
Pete at one time said the "blue" popcorn dissolves with water, if this is true it would be nice to put a layer against the hull and pour the foam on top of that and once the water hits it and dissolves you will have a nice air gap between the hull and the foam....just a thought
Bob's2001
OK thanks, it's getting warm lately so it's time get that foam in and finish the floor. |
Bob Ed
83 2001 |
robman
Newbie Joined: October-29-2007 Location: United States Status: Offline Points: 19 |
I am replacing my floor and I need to order some foam, how much foam will I need?
Pour foam kits will typically yield 25 times the volume of the kit you buy. You will need to do some measuring of the space you want to fill and calculate. We also don't know what boat you are doing. The stuff isn't cheap so we don't want to over estimate.
