Boat Dr. VS 1964 American Skier |
Post Reply | Page <123 |
Wow, looks great. I like it much better with the correct windshield.
boat dr
Joe,I drilled a 1/8 hole at the flange for this reason,to by pass a little water to the manifolds.Have an idea to reduce the pressure tho......
If you have the time give me a call and i will bounce it off you. Sounds to wild to even post. Tim same stat that was it the motor for 5 years,I am only running mine in the lake,3 min. and she is in the water...boat dr 318 386 2825 billy |
barr68
Senior Member Joined: December-09-2005 Location: United States Status: Offline Points: 100 |
Beautiful boat , trailer looks excellent also! Jim B.
Nice looking boat. Would a higher temp thermostat have a stronger spring?
It looks freaking awesome, makes me excited to finish my 83 and get back to work on the 67. The cooling system is a tough nut to crack on those older setups. Yours is clean and looks awesome I wouldn't recommend doing to it what I think it would take to get the temp perfect, however... if it didnt push open the thermostat it would overheat the exhaust manifolds. I think you need a regulated bypass of the thermostat I think I have a thermostat housing with a bypass in it somewhere from an old interceptor, its not in great shape but it would give you an idea of how to modify yours. Basically I am thinking a whole next to the thermostat to allow a fixed amount of water through to the exhaust until the thermostat opens up after being heated.
I assume youre just running on the hose right now. If youre supplying the engine with a good supply of real cold water, perhaps theres just not enough of a load to get it up to operating temp. Have you verified that your stat is opening/closing at the right temp in a pot of water? |
boat dr
Tim, you have that in reverse,the project comes to a close soon.Karen wants to ride not look,lake test Sat.Timing, carb issues and a general run in to get ready for Green Lake.
Still am sure will have some bugs to sort out w/the cooling system,can't seem to get the water temp above 100 degrees.Raw water pump is making a lot of pressure,and think it is pushing the thermostat open,any ideas. Am using a mech. water temp so as to know xact temp............boat dr |
I dont know Doc, you sure seem to be milking this project. Why dont you water test her already?
Just kidding with you- I can tell you did a lot of work there. I have to admit that I was skeptical when I heard you were going with paint- but it looks beautiful. Lots of nice details all around. Cant wait for a ride! |
boat dr
Posting pics after rub rail installation,I can see a light at the end of the tunnel.What is that noise ? I hope it ain't a TRAIN>>>>>>>>>>>>>>>.boat dr
81nautique
You guys keep raising the bar, it's getting hard to keep up. Very nice, looking forward to seeing it in person.
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1128 |
Nice looking boat there Boat Doc. All of that hard work sure paid off!
bkhallpass
Wow. That's turning into one fine looking ride Doc. BKH
Livin' the Dream
boat dr
The project nears completetion,and not too soon.The Hi Teks required a new floor the floor new carpet, new carpet new paint new paint blah blah blah.......
