Damn rocks |
edamario
Groupie Joined: July-13-2019 Location: Holliston MA Status: Offline Points: 58 |
Posted: September-08-2019 at 1:13am |
Disregard stringer comment. There's PLENTY of info on this site. Reading away...
Thanks for confirming the coil/ignition pairing:) |
'79 Skitique - first boat
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10715 |
No red flags The Sierra kit is really a rebranded Pertronix and the 1.5 ohm Pertronix coil is a good match for it. |
edamario
I hear ignition system and I think "starting", aka the ignition switch. I didn't really understand what a coil did once the boat was started. The answer was probably right in front of my face... but fun thing about all this is learning plenty of new stuff. Now I know a bit more:)
The conversion kit was the Sierra Marine 5299 The coil I put in is a PerTronix 40011 Flame-Thrower 40,000 Volt 1.5 ohm Coil Hoping this doesn't raise any red flags! Bummer that I'm "up & running" just in time for the off season, but till some time to go. Onto the next topic, I've got some soft spots in my floor which I may remove/replace over the winter. Seems the recommend is if you're replacing the floor, you should replace the stringers. Would you agree? Seems like a very big job. I'm actually solid with carpentry, but pulling the engine etc fives me some serious pause. Thoughts? How do you konw if they are "bad".... and I saw someone mentioned saturated foam. Just how big a job is this? |
Glad it's running good
Numerous times on the forum here, me and some others have said something along the lines of "if you think it's a fuel problem check the ignition system and vice versa" It surprising how many times that saying has worked to solve a problem that has somebody stumped. It's a good saying to remember I learned it from an old fart a long, long time ago A lot of conversions are done with the old coil staying in use with no problem, but it may have just been the end of the coils life no matter what ignition system it was feeding. It's a good idea to get a new coil to go with the electronic conversion though So..............what is your electronic conversion and what is the new coil (brand and part number) just to be sure they're "properly matched" Now you can get the kids out in the boat again. |
edamario
Update for you Keno.
What I was experiencing (choking back) was the ending somewhat cutting out, on acceleration. Not electrically, but literally the engine feeling like it just wasn't getting what it needed. Air, gas, Elec... I don't konw how to explain it. You'd push the throttle and it would just choke at anything over 10mph. That said, Turin out it WAS electrical. When the points were switched out to electronic, the ignition coil was not updated. Replaced the coil and it runs like a complete champ now. I think what was happening was the coil was overheating, so not sending spark to the plugs, which were then not doing their job, and so on. I realize my description is kinda bunk... but long story... when updating your distributor from points, you gotta update your coil. Lesson learned:) |
I suppose "choking itself back" doesn't tell a whole lot, but if you do your choke and coil change, it's a start and maybe you'll fix it
edamario
Okay - 2 weeks gone by, and the transmission was NOT an issue. Once the cable was adjusted, it is just fine. I'm guessing that the impact of my little prop hit did something to the adjustment... but thats just a guess. Of course, one problem reveals another. Now that I've gotten to take the boat out a few times, I've a reoccurring issue. Runs GREAT art first. Then if I stop for a swim etc (which I do with my kids) and restart 30min or so later, it runs, but starts choking itself back at anything over 15mph. Going to replace the electronic choke on the carb, and noticed that when my points were switched over, they'd not upgraded the Mallroy ignition coil, which I think IS the issue. Just ordered a flamethrower 1.5... betting this resolves the choke out. I hope at least!
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3602 |
Running dry out of the water will quickly eat your impeller.
These boats do not allow a quick dry start on the trailer. If not in water the impeller self destructs. Sounds like your tranny may be Ok, that would be a bonus. Might look into what changed to cause the cable to be out of adjustment. Normally you set them once and they are pretty much good till the cable fails. Unless working on some other project you bumped or damaged the system. |
I'm kinda curious how this turned out after your weekend or 2 have passed by
edamario
I had shifted locally (not in water)... but was "searching' for neutral at the time. Once found, I set the cable base on neutral, vs ensuring forward on the shifter actually pushed the lever on the transmission ALL THE WAY forward. My mistake clearly.
Out of water, it now seems fine. Putting in this weekend and will know for sure then. Frustrated with myself if it's as simple as that... but would be happy to not have to rebuild I suppose. TBD. |
It seems like a long time back it was mentioned by more than one person to disconnect the cable and shift it locally.
It's hard to figure out if you did or didn't do that but if you did and it wasn't right, then all the cable adjustment in the world won't fix things. So.............. did you shift it locally and have no problems? |
two impellers on most Chryslers, not Fords
edamario
Hey Gary -
Before I take the transmission out, Im giving your cable adjustment more thought. Didn't make sense to me as all was fine "pre-rock", but on further inspection, I found that when in forward at the morse, the bracket on the transmission was about 3/8" from "all the way forward". Re-adjusted, and tested out of water. Seems to be working now?!? Will test in water this weekend, but I'm cautiously optimistic that I may not have to rebuild after all! I'll let you know. One more for you... while testing, I noticed the engine was getting VERY hot to touch (my dash gauge wasn't working). I ordered & will replace the water pump impeller as the exhaust isn't expelling water like it should. Question for you (or anyone else).. I've read on here that there are two impellers? Where is the second? Again, I'm running a PMC302. Thank you in advance. Eric |
edamario
Ha Pete. Sorry - thats part of my arsenal... along with the Velvet Drive manual which amazingly has break down & rebuild step by step. Thanks for the tip on the number of clutches. That would have got me scratching my head for sure.
Mark - really happy to hear you had success with no previous experience. I was mildly considering buying a rebuild for $850... but seems silly as I have the tools and the time. Thanks guys - Eric |
Now if you use my link and Gary's link together, when Wouter refers to pieces with their reference number in the manual you know just what he's talking about
Teamwork Gary As long as he's referring to the same manual it'll be good Wouter didn't disassemble the forward piston and cylinder and replace those seals though.
It looks great to me. Too bad one of us didn't do it. It would have been a great addition in the FAQ thread.
Whats wrong with the link I shared ?? |
I repaired mine with no transmission background, it was 25 years ago but it worked great after the fix, I only had a picture of the tranny parts to go by when I did mine.
It has been a long time but I remember it being pretty easy. At that time West Coast Correct Craft was right down the street for me and had all parts on the shelf. Back then it was easy to unbolt and lift out the tranny for repair. Might be much harder 25 years later. I would probably need a lift to get it out safely. |
You can find later versions of the manual on line also.
One other little thing....................count the number of clutch plates you take out and put the same number back in otherwise it'll be all bound up and constipated That applies to the forward and also the reverse clutches. The kit has more plates than you'll need. |
Nah, just asking You could try the link below though from the CCF reference section link It's easier than a C4 but it's good to have the manual. |
edamario
Winging it sounds like a bad idea. No, I chatted up a few shops, and am doing with someone who's done many auto transmissions in the past. I've found a schematic,. and will keep digging pre doing the job for sure, but it doesn't look much more difficult than a C4 transmission, but looks can be deceiving.
Do you have something to share?;) |
Do you have a manual to use for the job or are you just wingin' it?
edamario
@baitkiller
Part 1, no. Part 2, hmmm. @Pete - I hear you on adjusting the cable, and had done so. When it died in the water, we tossed back the engine cover, disconnected and tried to do it manually at the trans. N0 go there either. Appreciate the advice, and will file it away as it's super thorough, but I'm putting money on the rebuild. Kitchen table or not. |
baitkiller
Busted clutch disc. Rebuild is cake. Just don't do it on the kitchen table unless you're single or wish to be.
So Pete Did you just blow this off and decide to ignore the error in your ways ? I'll assume you did, so I'll post a link to the more complete kit that includes the steel and the bronze clutch plates so that all the clutch plates can be replaced. You should educate yourself on what a banner kit is For the next guy who might be wondering, here's the link link |
Weird? Maybe not. Besides trying to shift the trans at the trans shift lever, I think you had better review how to adjust the shift cables. Courtesy of Alan via Gary.
This may be some help- Velvet drive rebuild
edamario
Not at all. The engine sounds fantastic, and when working the transmission sounds just fine. It's just a violent clunk at too high an RPM when it finally jams into gear. Once going, it's 100% normal sounding. Weird, right?
As it's $300 for the parts (plus my mechanic minded father who's thankfully free) I think a full rebuild is in short order. Stopped by marineenging.com to discuss (they are in my town amazingly) and while they do superb work, and would rebuild for $850, I just can't stomach another $850 into this boat. It's become the proverbial "hole in the water...." Ha. I'll take pics through the rebuild & share. Should actually be fun I think. |
Eric,
Are you getting any unusual noises? |
If the damper plate is bad, you'll need assistance from no one to figure that out, it'll be terribly obvious. Any strange loud grating noises when the transmission decides to go into whatever gear it wants to? |
