  New Posts New Posts RSS Feed - Motor switch
Motor switch
jterr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Topic: Motor switch
    Posted: August-10-2018 at 5:24pm
Suggestions-
I have a 79 SN with a 351 /new long block(about 300 hrs), and in the process of redoing my 83 SN which also has the 351-
Should I change motors as when I'm done with the 83 restore will probably sell the 79. Can't go through another redo
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2018 at 7:35pm
John,
If I understand correctly, you have a rebuilt 351 out of the 79 that you want to put in the restored 83 correct? What's the issue with the engine in the 83 you are restoring? Why not keep it in the 83?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2018 at 10:09pm
Correct. The 83 was not taken care of as was the 79. We just took the 79 out for a spin runs great.
The 83 I have gotten to run but sure needs work. When I checked compression it was cold but all were around 112.
PO mounted the coil to the valve cover, ????? you would have to see it
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 8:41pm
I have decided to put the 79 motor in the 83 and was wondering if the transmisions are the same??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 8:46pm
John,
Are the ID plates still on both transmissions? Take a look but they should be the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2018 at 9:17pm
Will check tomorrow, Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 2:33pm
Finally checked and the 79 is a -001 and the 83 is -003. From what I read the 003 is better. Where would I find a rebuild kit?
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 4:14pm
It is not soo much better that you would likely ever notice, but yes generally later is better. www.ebasicpower.com for parts and rebuild kits.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 4:29pm
John,
Were ether of the Trans's bad? Wondering why the rebuild is needed. My 64 Velvet still runs without ever being touched.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 5:18pm
Here's a link to an old thread. The 003 is beefier in the reverse section.
Like Joe said, not much difference and Ebasic power is a good outfit for Borg Warner parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 5:29pm
John,
I just have the motor and tranny out of boat and knowing the previous owner -it needs it.
