  New Posts New Posts RSS Feed - Battery Replacement
Battery Replacement
Otto Throttle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Topic: Battery Replacement
    Posted: February-22-2018 at 12:50am
OK... I have a 1999 19’6 closed bow. The battery in the boat does not allow the top lid to close. The manual has nothing in it about Replacement type. Can anyone offer a suggestion on the type and size that allows the battery lid to seat completely down as it was designed to do!
Thanks
Otto
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2018 at 3:32am
Mine states the battery group size on the underside of the battery cover. It's in storage or I would check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2018 at 8:40am
Group 65
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2018 at 3:08am
Thank you!
Otto
gt40KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gt40KS Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2018 at 11:40pm
Group 34M should work also. Choices are scarce and expensive for our boats. Both Odyssey, Northstar and Interstate make highly rated AGM's in a size that will work, but they are pricey.
JCCI
1995 Ski Nautique GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2018 at 7:21am
The "m" (marine) is not needed. Just use a group 65 starting battery like Tim mentioned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2018 at 10:00am
Dekka batteries, made by East Penn, is still made in USA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2018 at 5:54pm
The battery box lid on the boat says group 48....It is hard to find a group 48 battery. Interstate has one one for $166.00. what say the group??? Any other suggestions?
Otto
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2018 at 6:09pm
Don't buy the highest amp rated battery.   The lower Amp rated batteries are in the same size case and the plates are smaller. This leaves more room for them to vibrate in a boat as you bounce over wakes without the plates touching each other.   Makes for a longer life battery in a boat application.   I would look at 650CCA rather than the 800+ models.
It will save you money upfront and in the long run in a boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2018 at 6:20pm
Here's an old thread talking about this. It's been hammered out numerous times
Unless you're hell bent on getting a Group 48 for some reason, TRBenj's Group 65 or a 34 from Uncle Wally's battery emporium should do just fine at a reasonable price unless you're equally hell bent on spending a lot more
Group 34   10.3 long 6.8 wide 7.9 tall
Group 48   12.1 long 6.9 wide 7.6 tall
Group 65   12.1 long 7.5 wide 7.6 tall
.link
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2018 at 1:09am
Group 65 was a winner and fits perfectly😎 Thanks everyone🚤
Otto
