  New Posts New Posts RSS Feed - Alternator bracket broke
dockedwages1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dockedwages1 Quote  Post ReplyReply Direct Link To This Post Topic: Alternator bracket broke
    Posted: August-30-2016 at 12:06am
1982 SN with 351 pcm. Bracket broke at mounting hole when I was tightening belt. The bracket says R090055. The engine is a right hand engine. Why do most of the place I find this bracket for sale say it's a left hand bracket?
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2016 at 6:53am
If you do a "GOOGLE" of that part # you will find a CCF post from May 11, 2013 of the same topic. All your answers are there. Good luck
        1978 Mustang (modified)
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2016 at 8:10am
'92 Correctcraft Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2016 at 8:26am
Originally posted by JPASS JPASS wrote:
Link to thread
JP,
I'm glad you found the thread and linked it. I tried several key words googling and even used our own search without any luck. Thanks.
Tom,
Looks like a call to Skidim is in order. BTW, don't over tighten that pivot bolt again!
Duane,
Why didn't you copy and paste?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2016 at 10:09am
I 'm glad you found the thread and linked it. I tried several key words googling and even used our own search without any luck. Thanks.
Duane,Why didn't you copy and paste?
Pete, I think "speed reading" got ya again, No key words needed, just the   part #   like the posting said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2016 at 10:12am
Pete,
Cause I don't know how to post the "Link"
Got any advice??
Chevy350 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy350 Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2016 at 10:22am
Pete,
Got any advice??
Go to full reply instead of the quick reply. It makes it much easier. Click on the globe and enter what you want to name the link, an example like what JPASS put. Then paste the link from what ever you are linking.
1972 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2016 at 10:32am
This is the address that appears at the top whenever you open a page. You highlight it (comes up blue), then right click and right click "copy" then paste.
Trust me, I being close to your age, I had some learning to do!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2016 at 6:10pm
There really is a difference in the brackets and you can see it in the picture I attached or you can follow the earlier link back to the 2013 thread and see the difference in the picture posted by Old School Blue 84..
It's not the best of pictures but you can see that the depth of the mounting bosses is different by about 1/16 of an inch which in turn spaces the alternator out from the circulating pump differently since the bracket mounts to the pump..........which then messes up your pulley and belt alignment, which then makes messy black belt dust that gets everywhere
Might be a difference in water pumps since there were different pumps for different rotation at one time,(emphasis on "might". here) Now you can just buy a bi rotational water pump
Whatever the reason, there is a difference.
My black one came from SkiDim and it gives me good alignment on a LH engine.
The gray one was from a RH also with good alignment.
Like Pete said to Kostas in the 2013 thread linked earlier in this thread " it would be a good idea to check your pulley alignment" when bolting everything back together
KenO
