Gas Overflow |
tapenick
Senior Member Joined: May-17-2008 Location: United States Status: Offline Points: 185 |
Posted: August-21-2011 at 2:21am |
I've tried putting the gas nozzle in different positions and using different fill speeds but no matter what I try gas overflows. Any suggestions? 1990 Sport Nautique if it matters....
Tom |
Morfoot
Tom, from my experience when filling up the boat they all do it.... it's just the nature of the beast. Only solution that I have found is when filing her up you'll need to listen as the gas is going in. You'll here the pitch change when she is almost full or pretty close to it then you'll know to stop.
Only problem you have is when some idiot has his BOOM BOOM going so loud while he is filling up his ride that you can't hear it then you'll have to lower your ear to listen and hope you shut it off before you get an ear full of fuel. |
Tom,
You are talking about it coming out of the vent correct? |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1736 |
I think he is experiencing the problem when filling. Gas is not going down the tube and spilling or gurgling.
OverMyHead
If you cant afford to fill the tank full its not a problem.
1987 Ski Nautique |
Keeganino
Sounds to me what he is describing is a problem during fueling not when the tank is full. Open up the pump all the way and it squirts back out of the receptacle. Right? I have a funky bend in the 6" hose going from the receptacle to the tank which constricts the flow and makes it a real PITA to fuel up. For now my solution is that I only get gas from the one place I know I can control the flow. (also happens to be the station that has the best deals on 93) Makes it real exciting when I am at a marina in the water trying to fuel up. Seems like marinas always have monster pressure at their pumps.
For your situation, if this is the problem, I would say take a look at the path the fuel follows from receptacle to tank. Are there any major bends, or anything out of the ordinary along the way? Maybe there is a curve to it and has sort of collapsed? I am not sure what I am going to do about my problem. The best solution for me might be to make a hard elbow out of pipe and then use the hose to connect it to tank and receptacle. For me its mostly been a problem when I go out of town to an unknown gas station or marina. |
1973 Skier |
tapenick
Mostly just when it gets completely full.. gas gushes out of the fill hole. (not the vent)
Tom |
MartyMabe
Guessing game on this one. Just watch your gallons-- think about what it's gonna take to get full, start slowing down-- Just like a man--- wanting to do everything quick Gotta go slow and let her enjoy too !!
Yours like mine has a tricky bend where it goes in -- The Fuel Fill Hose guys! It is a sharp "S" on it's side. Until it gets air- it'll explode on ya like that--MESSY! MESSY! MESSY! I would have trouble with mine at first, until I figured that the safety cable that holds the fuel cap was kinking and getting in the way of FULL INSERTION! Now that I straighten the cable out, it goes all the way in, deep, and no problems since then. So experiment with her and take it slow----- I'm still talking about fueling the boat guys! |
I thought I'd help Marty explain himself better by cutting out some unneeded wording. What Marty was really trying to say is this... I would have trouble with mine at first, until I figured out it was kinking Now that I straighten it out, goes all the way in, deep no problems FULL INSERTION with boat fueling guys |
scottb
Senior Member Joined: July-05-2006 Location: Bolingbrook, IL Status: Offline Points: 376 |
I have the same problem with my 2000 Sport.
Solution: slow and steady wins the race ... and like Morfoot said, listen for the sound to change as it nears the top. |
IAughtNaut
What works for me is to hold the pump handle upside down and NOT insert it fully...just the tip, that way there's air flow around the nozzle. Then slow and steady. Mine overflows if I rush it no matter if its full or empty. The gas dock guys at my marina don't even try to help any more, they know it'll take twice as long if they do.
Try to just flip 'er over, only stick it in a little, then squeeze gently. Works every time for me. |
SharkSN
Senior Member Joined: August-23-2010 Location: Sproat Lake Status: Offline Points: 119 |
I fought this for years then found the problem when relocating the HUGE honking tank (1997 Ski) the vent anti-spill valve is a rubber ball that needs to be in the vertical position to work right.
CC installed it flat. |
Please read the thread again. This is NOT a vent issue and the reason I specifically asked the question!!! Paul, you are ADD |
SharkSN
if a tank can't vent the gas gushes....... i can read cheers, |
