98 Ski Nautique Blowers are LOUD! |
Author | |||||
IntelSoftApps
Senior Member Joined: April-12-2011 Location: WA Status: Offline Points: 144 |
Posted: July-23-2011 at 4:36am |
Thats right! I remember now. Anyways, nice boat. I like the colors
east tx skier
Senior Member Joined: August-22-2006 Location: Tyler, TX Status: Offline Points: 248 |
I know. Mine has always been noisy for sure. I posted a review about it on fifteenoff.com about it several years ago. I have certainly posted pictures of it on this site and others. Good chance you have seen some of the pictures before. I get around to quite a few boat forums (and that's probably putting it mildly). |
IntelSoftApps
Im working on it lewy2001
lewy2001
Just replace that blower please
IntelSoftApps
I didn't mean like the whole thing is a problem. What i meant is that the loudness of them after awhile is always in a 98 ski nautique. Also, did you ever post a story or post about your boat??? It looks very familiar. Like i have seen it online a few times... |
east tx skier
Will do. but I don't know of I would call a blower that still works after 13 years a problem. |
Bri892001
Maybe it has something to do with the location of the blower on the 98s?
On the older boats, there pretty much under the motorbox. |
IntelSoftApps
Let me know hoe it goes! and if the blower is quieter! It seems like the 98's are the blower problem boats... |
Fibersport
Groupie Joined: September-30-2008 Location: Lansing, IL Status: Offline Points: 76 |
Not to challenge anyone, just would like to make a correction for those that followed Pete's engineering analysis on electrical load and the horsepower loss. Pete, you're off on your wattage, should be 36 watts (3A x 12v). I've looked around and found that a 60 amp alternator draws about 1.5 hp, the 3 amp blower really wouldn't add that much draw, in the order of 0.056 hp (36W x 0.00134). Add the two together and you end up with about 1.556 hp.
east tx skier
Ha! I just googled the same thing. My 98 SN Blower sounds like a bad power tool. I bought another one and thought I'd get a heads up on how they go in before diving into it. I run mine before the initial startup and usually on subsequent startups if things have been sitting for a while. With gasoline vapor being more dense than air, I'm not confident that just opening the motor box is going to do much with any vapor pooling in the bottom of the bilge. This is my method. If what other people do has not caused their boat to become a briquet, more power to them. |
IntelSoftApps
Ya thats fine, but then he cant go and blame me for not reading the posts! |
OverMyHead
The CCF path is rarely a straight line. You can learn more here by accident than by design from most other sources, nothing wrong with a little extra background or an opportunity to for others to get some of their questions discussed also. Its not always just whats in it for YOU. |
1987 Ski Nautique |
DrCC
Sorry, Thought you meant this type of Blower. |
IntelSoftApps
Like i said before... What do you think i am doing!
I know about the vent system while moving and i know lifting the engine cover is a good idea. Its common sense. I know why the blowers are there too. I was forgetting about this, but then some moron wanted to get all scientific with this and see there are only ONE blower not blowers. Then another idiot said i wasn't reading the posts. If i wasn't reading the post how would i respond to the posts and i wouldn't be getting a new blower. And yes the BLOWER is cheap, but they should not be as loud as mine. They are pretty quiet when new. So thanks to all who helped and not thanks to who all didn't. I am getting a new BLOWER and will install it and it will be quiet. If anyone else responds to this post saying i am not listening... They are the ones that keep going on with this whole thing because i READ THE POSTS and i FOLLOWED what they told me to do! |
kapla
wonder the same Tim...its a blower!!! $50 go buy a new one a forget about it!!!!
You got an explanation as to what is causing your noise, as well as the probable root cause as to why the blower is starting to fail. You even got some insight into the technical parameters involved. You also got good advice as to what to do (buy a new one and replace it) and where to get it. Seems like this thread has come full circle... why is it still going? |
Bri892001
I run mine intermittently. Once at startup, then, every time I slow down and stop to change skiers, I run it for a few. Then I'll run it for a few before I cover up the boat when I'm done with it. I agree that when you're moving forward you don't really need it.
Are these things like bath fans? By that, I mean, will a few extra dollars spend on a better quality replacement give you lower sound levels? |
dochockey
The blowers were put in there because there was an explosion, one should always lift the cover before starting the engine just common sense,checking fluid levels etc.
These blowers are cheap the decibels levels are not going to be that low. These boats have a vent system, when you are on the move fresh air goes through the front vents through the engine compartment and out the back so at this point you don't have to run the blower. |
1989 Teal Ski Nautique
IntelSoftApps
All you are doing is talking about horsepower and watts and what not! Basically Stuff half of the people dont care about. How is talking abut the horsepower loss while running the blower while under power in a thread about something COMPLETELY different help me???? |
IntelSoftApps
I have read them all by the way. It is the same stuff i always here in threads like this! Dont use it and stuff like that or vice versa.
I am not, not going to use it because that is kinda of a risk. But yet, i would prefer to replace it, because i usually have it on always... Unless, i am missing something or am blind... thats what was really offered. Anyways, thanks for the help to all who helped. I will replace it and enjoy a QUIET blower |
Well, you do but it requires reading all the responses in this thread!!! D you have a problem with that?? |
IntelSoftApps
DANG! Lol. What do you think i am doing. I dont have any other option... I Think
mdvalant
IntelSoftApps
Ya thats what i mean. Same difference. Doesn't really matter who many there are. I am not trying to get all specific. I guess, now i am trying to ask why is IT so loud? |
mdvalant
When you say blower(s) I think you really mean blower. Unless changed otherwise don't all Nautiques of the newer eras only have ONE blower on the starboard side just under the motor?
I love a good blower, much better than a good handy any day. |
IntelSoftApps
Thank you M3Fan! I will look at it when i go back to that side of the state on thursday!
If at one point in time the water did get up to the blowers would they be affected still even if it happened many years ago??? |
M3Fan
That generation of Nautique typically has them mounted in the engine bay, just below the level of the floor. So, water topping off the bilge would do it.
IntelSoftApps
No matter how many threads or post about blowers there are, there is always the people that say screw it or always leave it on. I personally turn it on and usually forget about it and leave it on. But this one is pretty hard to forget about.lol
Also, someone mentioned about water to high and got into the blowers...were are the blowers located and how high would the water have to go for that to happen???? |
Steve,
Safety with boating is always on my mind but, I feel the use of the blower is overly rated. However, I'm mechanically inclined and feel checking under the dog house for fuel leaks and odors is way better than counting on the blower. The running of the blower at all times I feel is related to people who are less competent mechanically and the liability insurance company suggestions!! As mentioned, my 54 and 64 has none!!! None of the older boats had them!!! It was common sense back then. |
M3Fan
Blowers get loud when they get immersed in water. At some point in time somebody probably let the bilge fill up to the brim in that boat. Replace it and enjoy the silence.
